WaltonsMountain
Put a Vista Ultimate x64 build together on Saturday.
Specs:
Mobo: Gigabyte ep45-ud3p
CPU: Intel e5200
RAM: 4gb Patriot Viper DDR2 SDRAM 800Mhz
Video Card: ATI Radeon HD4870
HDD: 2x 640gb WD Caviar Black (Raid 1 array)
Case: Antec Sonata III (1 120mm exhaust fan)
PSU: Antec Earthwatts 500w
CPU Cooler: Artic Freezer Pro 7 w/ Artic Silver 5 thermal compound
Problem: Starting to get random BSOD's (about 1-3 per day)
Technical Information on BSODs:
*** STOP: 0x00000109 (0xA3A039D89692950B, 0xB3B7465EE90F613B, 0xFFFFF80002221CB0, 0x0000000000000001)
0x00000109 (0xA3A039D89692950B, 0xB3B7465EEAA9A1F7, 0xFFFFF8000210A430, 0x0000000000000001)
*** STOP: 0x00000109 (0xA3A039D89944866F, 0xB3B7465EEBC1529F, 0xFFFFF80001EE7D30, 0x0000000000000001)
SYSTEM_SERVICE_EXCEPTION
***STOP: 0x0000003B (0x00000000C0000005, 0xFFFFF9600027A05D, 0xFFFFFA60081D2BB0, 0x0000000000000000)
*** win32k.sys - Address FFFFF9600027A05D base at FFFFF960000f0000, DateStamp 498fa36b
Again, these BSODs happen about 1-3 times a day randomly.
All drivers (chipset, videocard etc) are UP TO DATE.
Temperatures (via HWMonitor):
Intel Pentium E5200 hardware monitor (idle)
Temperature sensor 0: 39°C (102°F) [0x3D] (Core #0)
Temperature sensor 1: 39°C (102°F) [0x3D] (Core #1)
*CPU temps go up to 50-51°C under load.
ATI Radeon HD 4800 Series hardware monitor (idle)
Temperature sensor 0 71°C (159°F) [0x47] (GPU Core)
Voltages (via HWMonitor):
CPU VCORE: 1.12V 1.12V 1.18V
DDR: 1.92V 1.90V 1.92V
+3.3V: 3.3V 3.3V 3.3V
+5V: 4.92V 4.92V 4.92V
+12V: 12.10V 12.03V 12.16V
VBAT: 3.18V 3.18V 3.18V
There has been NO OCing on this build!
I have run MemTest86 successfully with no errors (individual sticks and together)
I ran Prime95. Not very familiar with this program so maybe you can help me with the results. Both workers stopped their tests twice 1 minute in....
[Apr 30 15:10] Worker starting
[Apr 30 15:10] Setting affinity to run worker on logical CPU #0
[Apr 30 15:10] Beginning a continuous self-test to check your computer.
[Apr 30 15:10] Please read stress.txt. Choose Test/Stop to end this test.
[Apr 30 15:10] Test 1, 4000 Lucas-Lehmer iterations of M19922945 using FFT length 1024K.
[Apr 30 15:11] FATAL ERROR: Rounding was 0.5, expected less than 0.4
[Apr 30 15:11] Hardware failure detected, consult stress.txt file.
[Apr 30 15:11] Torture Test completed 0 tests in 0 minutes - 1 errors, 0 warnings.
[Apr 30 15:11] Worker stopped.
[Apr 30 15:14] Worker starting
[Apr 30 15:14] Setting affinity to run worker on logical CPU #0
[Apr 30 15:14] Beginning a continuous self-test to check your computer.
[Apr 30 15:14] Please read stress.txt. Choose Test/Stop to end this test.
[Apr 30 15:14] Test 1, 4000 Lucas-Lehmer iterations of M19922945 using FFT length 1024K.
[Apr 30 15:16] FATAL ERROR: Rounding was 0.498046875, expected less than 0.4
[Apr 30 15:16] Hardware failure detected, consult stress.txt file.
[Apr 30 15:16] Torture Test completed 0 tests in 1 minutes - 1 errors, 0 warnings.
[Apr 30 15:16] Worker stopped.
[Apr 30 15:10] Setting affinity to run worker on logical CPU #1
[Apr 30 15:11] FATAL ERROR: Rounding was 0.49609375, expected less than 0.4
[Apr 30 15:14] Setting affinity to run worker on logical CPU #1
[Apr 30 15:15] FATAL ERROR: Rounding was 0.5, expected less than 0.4
[Apr 30 15:15] Hardware failure detected, consult stress.txt file.
[Apr 30 15:15] Torture Test completed 0 tests in 1 minutes - 1 errors, 0 warnings.
[Apr 30 15:15] Worker stopped.
I would be happy to give you guys any information you need. Please help me... i've installed the OS twice and still get these random BSODs....
Specs:
CPU: Intel e5200
