I am having problems with the free version of ‘Real Player’ it downloads and plays OK but the folder ‘Real Player Downloads ‘ does not respond properly and just about freezes to such an extent that it becomes unusable I tried to un install it but you are always left with a folder in (computer program files that will not delete) I have even done a DELL restore which restores your computer to the state it was in from new this did remove it but when re installed it went ok for a while then back to its old problematic self, All my updates are current, I do not know if the fault is with Real Player or Vista so I am seeking advice on:
Is the a way to fix it?
What is a good program for removing Real Player and programs such as this?
What is a good free video down load program that will handle more than one down load at a time. Thanks in advance
