Recovering system
Filzmoos
My computer suddenly turned itself off the other night whilst I was reading a web page. When I rebooted it, wavy lines appeared around the 'vaio' symbol and lots of noughts appeared on the screen. It wouldn't open any further and remained on a blank screen. I was able to open the computer in 'safe' mode by continually pressing the F8 key so was able to remove all my files. I have successfully restored the system before so decided to try it again and went through the procedure using my recovery discs. Everything appeared to work and the computer restarted itself, displaying the following message: Please wait a moment while windows prepares to start for the first time……………. Unfortunately this is as far as it goes!
Can anyone help?
    SONY VAIO VGN-AR71E
How long did you let it go when you got that message? I would let it go an hour just to be sure it's not doing anything.
Do you have any USB peripherals attached besides your keyboard and mouse? If you do, disconnect them before you start the recovery.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
Did you get a picture of the issue before the restore?
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
I left it two hours and have nothing attached
    SONY VAIO VGN-AR71E
