Solved Recycle Bin Button Won't Work - Tried Everything
Although, I am surprised I am glad that it worked out for you.
That's great news Foxtrot.
The .reg file at your link restores the default registry entries for the Recycle Bin. Normally these do not get messed up on their own. Did you use any type of registry cleaning program?
Just CCleaner. Do you approve of CCleaner?
I think the problem was malware. I have AVG 2014 (paid version) and I occasionally run scans with Superantispyware (free version (Quick scan)) and both found 0 threats on my computer. After I posted my question on this forum, I thought I would try Malwarebytes, which I used years ago, and I ran it in safe mode. It detected multiple PUP's and removed them. I am done with AVG. I still like Superantispyware for removing adware tracking cookies, but I'm going to get the paid version of Malwarebytes soon unless you recommend something better.
    HP Pavilion a6000n
CCleaner is usually pretty safe.
Malwarebytes is a good choice as well.
With the Malwarebytes scan, I bet most were Optional type, not actual threats. Also, most malware re3moval folks I've chatted with say MBAM by itself is not sufficient and you need to have another AV program.
I have MBAM Pro and also use Windows Defender in Windows 8. On Windows 7 I have MBAM Pro and Microsoft Security Essentials.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB Seagate ST2000NM001 2TB Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot) Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
