Recycle Bin - No menu or properties! PLEASE help!
luvarainienight
I can't use my recycle bin without either going into the recycle bin and deleting the files that way or using disk cleanup. When I right click on the recycle bin, there's no "empty recycle bin" option, and when I click on properties, it says "the properties for this item are not available." I have tried putting the info back into the registry to repair it, and a few other things I've found in the forums to try but to no avail. Is there some way to "reinstall" the recycle bin? Reformatting is not an option at this point because I have many, many karaoke files that I can't back up right now. Thanks in advance for any help!!
~ Terri ~
You could try a system restore to a point before you had the problem
Hope it helps
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
I tried the system restore. It couldn't restore. I haven't changed or deleted anything that should have affected the recycle bin ... I just don't understand how this happened. I've tried every "recycle bin fix" I've been able to find on here, and done the sfc /scannow.
Thanks for the advice, anyway. =))
Hi Terri, and welcome to Vista Forums.
As a workaround until you can backup you karaoke files, you might try creating another administrator account and see how the Recycle Bin works in it. If it works just fine, then you can copy the contents of the old user account's C:\Users\(user name) folders into the new accounts same folders.
