Recycle bin properties
tedb
New to the forum here. I have a problem with the Recycle bin in my Windows Vista 32bit that i could not find a fix.
I've read thru all the posts about the recycle bin in the tutorials but still couldn't find the answer.
The problem i have is when i delete something, it doesn't show in the recyle bin. I can only access the deleted contents from windows explorer. Whenever i right-click the recycle bin icon properties on my desktop windows show the error message "the properties for this item is not available"
I can't even set the recycle bin storage since i can't get the recycle bin properties window to appear.
Is there a fix for this ?
Thanks,
Rich and Brink. I've tried all the solutions above but it didn't work for me. The gpedit function i can't do since i am running on 32bit Vista Premium
The recycle bin properties is there but i can't access it when i click on it. This is strange since it's only happened with the recycle bin shortcut on the desktop.
When i tried to click on the recycle bin properties context menu Vista still showing me an error box that said "the properties for this item is not available"
Might have to reinstall :(
Brink,
The recycle bin properties is on the context menu. The problem is that when i select it Vista will give me the error mesage
I only want to get to the properties to change the recycle bin storage size
Guess i will have to use system restore :cry:
Yes, that would be the same error you would get if "Properties" was set to be removed using either option in that tutorial above, but the computer hasn't been restarted to fully apply the policy yet. That could be why Properties could still be there, but give you that error when trying to use it. I was wanting you to check that to help make sure that Properties is set to be added just in case that may be the issue to hopefully avoid more drastic measures. That's all. :)
