Hi all,
Not sure if this is the right forum. Apologies if not.
I have a nit problem that has followed me from XP and maybe earlier. When I install an OS, I normally have the swap on a drive other than the OS. This seems to confuse the recycle bin in that if I delete something, it will not show until I reboot. When it then shows full, and I empty the bin, it still shows full. I deleted the cache (came back exact same size) and deleted the bins on the 2 raid sets and the sata drive. They reappeared but the desktop bin has the same behavior. More a pita than a major issue. BTW, 20GB memory, so deleted the swap, Ideas?
Joe
Update:
I associated the empty with full. and the full with empty, and applied. I then reversed the process and applied. I'll be darned, but it worked. FYI
http://www.vistax64.com/tutorials/66294-recycle-bin.html
Joe
Update:
