refillable compressed air cans
Where can I get refillable compressed air cans?
    Self built
    AMD Athlon 64x2 6000+ 3.0ghz
    Asus M4N78 Pro
    3Gb PC2-5300 DDR2 @ 667mhz
    VIA HD Audio
    OEM HP
    OEM HP
I have never seen refillable canned air (Dustoff, etc.). What we used to use in the Photo biz, were tanks of dry Nitrogen, usually available from suppliers of welding gas. Just a thought.
At work we use the non-refillable cans for most work.
If it needs even more, we use an air compressor (much more likely to damage a system, but we only let the more experienced techs do it).
Brink:
I did do a google search prior to posting my question. I came up with the same results. Mostly aerosol cans that can be refilled. I was looking for the same type of nozzle exhaust mechanism as the Clean safe dust remover.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
I can't find any either. :(
If you have a air compressor, and depending on what you wanted to use it for (assuming the computer), you could use a compressor moisture trap on it so that you can use it to blow the air directly from the compressor to clean dust from electronics safely.
AIR COMPRESSOR FILTER PRESSURE REGULATER MOISTURE TRAP - eBay (item 260293492212 end time Oct-23-09 19:19:29 PDT)
or
Moisture Trap (bad50-051) Badger Airbrush Co. Airbrush Accessoryhttp://www.google.com/products?q=compressor+moisture+trap&aq=0&oq=compressor+moist
I ended up in getting the Aerosol spray can from harbor freight. In store price is $9.99 in my area vs. online of $4.99 plus s&h and wait time ends up almost the same. Now I have to head off to work(golf pro shop), will check it out and report back on how it works and ease of use.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
The only issue i would see with re-filling would be moisture...which could cause problems.
    Intel Q6600
    ASUS P5K MBoard.
    4G OCZ PC2 8500 Platinum
    EVGA 8800GTS Vid Card
    500G Seagate SATA 200G Seagate SATA 100G WD Caviar SATA 80G WD Caviar IDE
    OCZ Elite 800W PSU
    RaidMax Smilodon Case
    Lite-On dual layer DVD burner X 2 Dos 6.2;Win2K;XP; & Vista Ultimate 64Bit.
Yep, the compressor would need a moisture trap. :(
Sorry...i missed that link in your Post.
Must. Have. Coffee....
    Intel Q6600
    ASUS P5K MBoard.
    OCZ Elite 800W PSU
No problem. I know what you mean today. ;)
I have a moisture trap on my compressor all ready. I'm good to go there. What I'd like to do is get some of the ingredient, bitterent, which the company uses to take out moisture and as a deterrent against huffing. Then figure out a way to get the right ratio. I have contacted the company via email but I have not received any word yet.
    Self built
    Asus M4N78 Pro
    VIA HD Audio
    OEM HP
    OEM HP
    Intel Q6600
    ASUS P5K MBoard.
    OCZ Elite 800W PSU
