RePartitioning Hard Drive
Rusty8809
I recently reformatted my hard drive and I would like to change the size of the partitions.
I am using an HP Pavillion dv9700 laptop with a 220 gig hard drive and Vista Home Premium.
I would like to shrink D: and expand C:. When I right click Computer and select Manage I can successfully shirnk D: by 30 gig and it shows that 30 gig is available, however, when I try and Expand C: by 30 gig the Expand option is not available.
Do I need to reboot first before trying to Expand C: or is there another option?
Help is always appreciated.
Hello Rusty and welcome to the forums :party:
Yes, you need to reboot before trying to edit another partition.
That partition change hasn't been made yet and will be done when you reboot. Then you'll be free to edit your other partitions :)
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Thanks for the reply, however, that didn't seem to solve the problem.
I shrank the D: drive; rebooted and went back into "manage" however, the
C: drive "expand" was not available...."expand" was only available on the D: drive.
Any other suggestions?
You cannot change a drive that is in use.
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
Thanks for your help.
Attached is a screen shot --- hope it helps.
That's why you can't expand it, D partition is on a separate physical drive.
What are you trying to do? make more room on C?
    Asrock P67 Extreme4
    auria eq2367
I really feel like a knucklehead. I had no idea that my laptop had two physical hard drives. I thought I had one 220 gig drive that was partitioned.
I'm trying to give myself more room on C: but I guess that's not possible.
Thanks for all of your help. I did learn something.
You're not a knucklehead, you learned something. :)
You can move your user folders to the D partition to give you more room on C.
Here's a tutorial for moving user folders to another location,
http://www.vistax64.com/tutorials/107990-personal-user-shell-folders-move-location.html
Follow the steps in method one, any questions just ask.
This is a good idea anyway, since it separates your data from the OS if some unforeseen tragedy were to occur.
    Asrock P67 Extreme4
    auria eq2367
