Please don't run away because this appears long. I'm just providing as much background info as possible to pre-answer any questions someone might have. I've been through so much stuff in this forum and on the internet that I'm now thoroughly confused. I've been trying to figure this out for several months now and it's driving me crazy. Here's what is going on and what I need to do.
I need to replace my O/S HDD. I have a new larger HDD to install. I need software that will do the following:
In my computer, my current HDD is 500GB and I'm replacing it with a 1.5TB HDD. My girlfriend has a much smaller HDD that has started whistling, so I need to backup her drive ASAP and replace it. I have an external 2TB drive that I've shared on my network. I want to install the software on each computer to back up to the external drive. After the backups, I need to replace the drives and restore the O/Ss to their respective computers.
Q1) I've been looking at DriveImageXML, Paragon Backup and Restore Free, Macrium Free, and EaseUS Free. So far, EaseUS looks like it has the most options, but I'm not sure if it will work while Windows is running. Does anyone here know?
Q2) They say that only the Workstation version (2 for $59.20) will restore to different hardware. Does that mean it won't do what I'm looking to do?
Q3) In their comparison chart, for Scheduled Backups, all versions have checkmarks but the Free version also says (Part) where the paid versions say (Full). I don't know what that means. Does anyone here know?
Q4) If there is another software that I don't know about that will do the above, please tell me.
I've been trying to figure this out for months.
If you've managed to read this far, can you help me? If not, do you have any tips on where I can turn for help?
- Move at least two of the three partitions to the new drive. The third partition is a recovery partition put there by Gateway. I have a CD that will do the same thing so I don't think it's needed, especially if I don't want to ever use it.
- Create full backups of two computers
- Perform automated differential backups
- Run the backups while windows is running
- I'd prefer that it also let me restore a single or several files from the backup file, but it's not a requirement.
- Must be free. If I have to buy it, then I'll have to buy one for each computer and I can't afford that right now.
- Operating System
- Windows Vista Home Premium SP2, 32-bit
- Retrofitted Refurbished Gateway
- AMD
- ASUS M3A78-EM
- 4 GB
- Acer 22-in Flat Screen Monitor
- Logitech M705 Wireless Mouse
- Logitech K350 Wireless Keyboard
