Resolution problems
sirius 1000
Hi, I have a windows vista business (sp1) and when I start a game the screen becomes small.when in the game i go onto the resolution settings but it doesnt give me the option of making it higher than 1024 x something. please help.
Hello sirius 1000,
Can you list your system specs, also what game is it your trying to play and does it do it in all games or just the one ?.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
yeah, please let us know what kind of system you have and what game. There may be a patch available for the game?
    Core i7 920
    Intel X58
    6GB DDR3
    EVGA GTS250 512MB
    Realtek Audio onboard
    LG W2361V
    1920x1080
    1TB Seagate Barracuda SATA
    Corsair 650W
    Antec 1200
    stock
    MX Revolution
Intel Celeron CPU E1400 @ 2.00GHz
RAM 100GB
Windows Vista business 32-bit
NVIDIA GeForce 8600GT
1360x 768 monitor.
All games resolution options only go up to 1024x768
Thanks for your system specs.
1. Are all your drivers up to date ?. Go here and use option 2.
Drivers - Download NVIDIA Drivers
2. Has this always done this or just started.
3. When you say the screen goes small, does it go to window mode or is it a change in the screen resolution ?.
Most games will only allow you to set the resolution as high as your system can support, so it may be thats as high as you will ever get it, but lets look at other options first.
If you want to know if your specs will run a game go here.
Can You RUN It?
Post your results and we will take a look. Good luck.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
I just changed my computer to vista, it was an xp pro.
my desktop is set to 1360 by 768 and works but as soon as i go into any game it sets it back to 1024x768 and does not give me the option of any higher,i dont understand why it wont let me,it did when i was using xp.
I think you will find that the Max resolution your games will run at on this system is 1024x768.
Is this a custom build or a bought from shop PC ?. If bought what make and model is it ?.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Well your system should handle the resolution, what is the make and model of your monitor ?.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
i dont think it is the monitor i would say it is the video card driver for vista, try updating it and let us know what happens.
also did your games work in XP PRO in 1360 x 768?
and what games are you trying to run?
if they are older games that might be the highest resolution available.
    CUSTOM BUILT BY ME
    8BG PC5300 4 x 2GB OCZ
    Onboard 7.1 HD AUDIO
    55" Vizio LCD
    1600 x 1200 HD
    GENERIC
    MICROSOFT WIRELESS MOUSE
    MICROSOFT WIRELESS KEYBOARD
    CABLE 15MBPS
Did you use the link i gave you to update your drivers ?.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
