router help please
Double check the documentation or maybe do a search online for hooking up your model of router. But im pretty sure you wont need it on either.
    Toshiba Laptop A505 S6965
    Intel Core2 Duo P7350 2.0Ghz
    4Gb DDR2
    ATI Mobility Radeon HD 4570 (512MB)
    16in.
    1366x768
    500gig
    10Mb/896Kb
You should be able to run the cd by going to: Start menu, Computer, and you should see the cd (probably D drive).
    4Gb DDR2
    16in.
    1366x768
    500gig
    10Mb/896Kb
    Windows 10 Home
    HP 8312 (Socket FP4)
    Microsoft Optical Wheel Mouse
    62.86Mbps down 18.19Mbps up
Hi Joan, I just got the router and just need a little help. My laptop does not autoplay the cd roms, and i looked on net and tried some suggestions how to get the d drive to show in computer, but i got stuck when i lowerfiles and upperfiles did not show. also do i put the cd roms into my laptop that i want to connect to the net
Thedarkside said, in the first reply to your post, that you probably will not need to. Google your router and see what online sources say about setting it up, or tell us what router you have.
    AMD Athlon 64 X2 Dual Core 5000+ 2.60GHz
    Biostar N68PA-M2T 1.0
    3006MB
    Nvidia GeForce 9400GT
    Envision 22" widescreen
    1680 x 1050max
Okay, did you Google it?
...put the CD in, click your pearl button and go to 'run'. type d: and then press OK. If 'd:' doesn't work, try 'e:' - I had a computer that didn't have a d drive before.
If you still can't find the CD on your computer, maybe it's time to download the driver from Belkin's website instead? Belkin : Support : F5D7051 Driver
    3006MB
    1680 x 1050max
Okay. From your phone line, you have the phone line hooked to ur modem right? If yes, then you have an ethernet from the modem to ur computer right? If yes, then i want you to take off the ethernet cable from the computer and plug it into ur router's WAN/Internet port (the on separate from the other 4). Then i want u to get another ethernet cable and plug it into (one of the 4 sockets that are together), then from that, you plug it into your computer where your Modem's ethernet cable was previously connected. Then i want you to type in 192.168.1.1 into ur webbrowser, and configure the SSID (name of the router), and a password for your router. After that you are ready to connect your laptop to your router. Okay, from your laptop, you should have wireless capabilities, i want u to connect your laptop to ur router wirelessly (the router that you want to connect to sohuld be the router that you have set up the SSID with), (right click that little computer sign and click connect to a network), and see if that works. Also remember to plug ur router into AC jack (powersupply).
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
You are using a DSL connection right?
    Hp pavillion a6110n
    4 gigs 3.3 useable
    generic pnp monitor
    normal black case
    fans
    dsl
    2.3 ghz amd
The wire runs from my modem into a box on the wall, the both ends of the wire sort of like screw into the connection, sorry don't know what its called
cable modem?
the screw connections look like this?
if it does, you have bought a router im assuming?
does your laptop have a wireless connection and finally, is it a wireless router?
these are essential questions that need to be asked to find out the best way to connect to the internet, you will not need a cd for it to work :)
    Intel Q6600 @ 2.8GHz
    Evga NF78-CK-132-A 3-Way SLI
    EVGA 560 GTX SC FTW 1GB
    Antec 900 Gaming Case
    Logitech generic keyboard
    16Mb Sky bb
it is a wireless router the laptop can go wireless but have not got the card for it, and the the wire to the back of the modem and to the white box on the wall as got like a 20p shape bolt to it
    16Mb Sky bb
