mysiar
Hi
I have few programs that I wanted to run as Administrator from startup for normal user.
I tried Task Scheduler and it worked but I didn't have icons for these programs in a tray so I could not control these programs.
Quite a bit of searching with google brought me to
CPAU
It is command line program which allows to run programs as different users.
In my copied this program to C:\WINDOWS directory and created shortcuts in Startup folder.
Example shortcut command line:
C:\Windows\CPAU.exe -u Administrator -p Password -ex "C:\Program Files\GBMPro8x64\GBMAgent.exe" -lwp
You just need to change Administrator and Password to your real username and password and it works great.
Hope it helps.
Regards
Piotr
CPAU
Hope it helps.
Regards
Piotr
- Dell Vostro 1700
- Core2 Duo T9300 2.5GHz
- Dell 0HX767
- 4 GB DDR2
- Graphics Card(s)
- GeForce 8600M GT
- SigmaTel STAC 92XX C HD
- 1920 x 1200
- 2 x 250 GB Hitachi 5200 RPM
