Running without updates
It may very well be the updates. Im just saying that we will not know for sure until the problem is fixed.
Yeah, no idea how to fix it other than run without updates.. :(
    AMD Phenom II x6 1055T 2.80GHz
    Asus M4A77T/USB3
    8GB DDR3 1666MHz
    ATI HD5850 1GB GDDR5
    21" Samsung, 20" Acer
After you uninstall, set the updater to notify and not install. Install a few at a time then test. When you get the bad one, uninstall. When you get it again right click and set to hide, that will prevent if from installing or it coming to be installed again.
thing is after installing every vista update, it was about a week until i started seeing symptoms again
    Asus M4A77T/USB3
    8GB DDR3 1666MHz
I don't let Windows update install updates automatically but I take care of it myself. However such a practice is not for everyone.
    Windows 7 Pro & 10 Pro
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB & 500 GB
