Scannow to fix BSODs
I built this computer last Sept, just over a year ago. For a few months it was perfect, then it started crashing (BSOD) at least once a day, 2-3 times is the average, but 11 times is the most I counted. So of course I've been trying to fix this for about a year now, I've updated all drivers, replaced parts, checked memory both with memtest86+ and by removing one stick at a time, and of course been through multiple long threads on forums. So finally yesterday one of the BSODs mentioned the file USBHUB.SYS which I had never seen mentioned before, so I Googled it and came up with a thread in this forum suggesting the poster should run ScanNow. So I did that and it surprisingly found and fixed some files. However it said some files could not be fixed and I would find more info in the CBS.log. I looked in the log but don't understand a word of it. I was wondering if someone here would know enough about it to look at it and figure out what I need to do. Thank you.
    Self built
    Q6600 2.4GHz Core 2 Quad
    Gigabyte P35-DS3P
    4GB Corsair Dominator + 2GB Corsair XMS2
    XFX GeForce 8800GTS 320MB 320-bit GDDR3
    motherboard
    24" Gateway LCD
    1920x1200
    C: = Samsung Spinpoint 400GB D: = Seagate Barracuda 1TB K: = an old IDE 60GB drive ripped from a Buslink external enclosure
    Antec Neo Power 650 Blue
    Apevia X-Cruiser
    4 80mm case fans
    Logitech MX Revolution
    Saitek Eclipse
    15Mb/s FiOS
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    MX Revolution
    Microsoft Comfort Curve
Thanks I'll look at that. I think I have done the repair install. If you're talking about inserting the Vista disc and clicking Repair, then yes, I have.
    Self built
    Gigabyte P35-DS3P
    motherboard
    24" Gateway LCD
    1920x1200
    Apevia X-Cruiser
    4 80mm case fans
    Saitek Eclipse
    15Mb/s FiOS
Well that's annoying, those instructions don't work. I typed in what it said in a command prompt (as admin.), hit Enter, and nothing happened, I just got another C:\ prompt So I typed in the next part ans it tells me "edit" isn't a recognized command.
Edit: OK I searched for that string manually and found the damaged files. They are all named similarly to this one "NlsData0045.dll" so I googled that and came across this site:
http://www.corruptedfilerepair.com/...ws-Operating-System-Microsoft-Corporation.asp
Anyone know if that site is trustworthy?
    Self built
    Gigabyte P35-DS3P
    motherboard
    24" Gateway LCD
    1920x1200
    Apevia X-Cruiser
    4 80mm case fans
    Saitek Eclipse
    15Mb/s FiOS
Sorry Phil, but I don't see where the command 'edit' is mentioned anywhere. I'm assuming that your talking about the SFC command. Make sure you have a space between the sfc and the /scannow. If that fails, then try it in safe mode. Also if you are in an elevated (admin) prompt it should read 'C:\Windows\system32>'.
Please keep us posted.
Gary
    Creative SB X-Fi
    HP w2207 + HPvs15
    MX Revolution
It's step 3 on that Microsoft link you gave me
3. Type the following command, and then press ENTER:
edit sfcdetails.txt
Actually you gave me a link to this forum, that page had the MS link
As I said in the first post I already did the scannow, I'm just reading the results now.
    Self built
    Gigabyte P35-DS3P
    motherboard
    24" Gateway LCD
    1920x1200
    Apevia X-Cruiser
    4 80mm case fans
    Saitek Eclipse
    15Mb/s FiOS
Ah. Sorry about that. I hadn't read the MS link so didn't know that command. Learn something new everyday.
Gary
    Creative SB X-Fi
    HP w2207 + HPvs15
    MX Revolution
Phil,
When I opened up my own cbs.log file I just did a search for "cannot" and/or "repair" to find all the lines that mentioned whether or not a file was repaired.
Richard
    H/P dv7 Notebook PC
    Intel(R) Core(TM)2 Duo CPU T5800 @ 2.00GHz
    Compal ID 30F4 Version 99.67
    NVidia GeForce 9600M GT
    WDC WD3200BVET-60ZTC0 ATA DEVICE
    Synaptics PS/2 Port TouchPad HID-compliant mouse
    IBM ENHANCED (101 or 102) keyboard
Yeah thanks, that's what I did too. Now I just need to know where to get those damaged files, like I said in post #4 I found a site but I wonder how trustworthy it is.
    Self built
    Gigabyte P35-DS3P
    motherboard
    24" Gateway LCD
    1920x1200
    Apevia X-Cruiser
    4 80mm case fans
    Saitek Eclipse
    15Mb/s FiOS
    2 x 1920x1080 @50Hz
    Asus M5A78L-M USB3
    32GB [4x8GB] DDR3 1600 MHz
    Samsung 32" TV
    68 MB Down 18.5 MB Up
Thanks it looks like that site doesn't list them but I found more info on them from that other site. Turns out they are related to a Crysis demo I had installed like 8 months ago and it never worked right anyway so I'm just uninstalling it, then I'll run Scannow again.
    Self built
    Gigabyte P35-DS3P
    motherboard
    24" Gateway LCD
    1920x1200
    Apevia X-Cruiser
    4 80mm case fans
    Saitek Eclipse
    15Mb/s FiOS
Not the Crysis demo, don't know what that site was talking about. So I downloaded the files and replaced them. Scannow still said they were bad. Then I crashed, twice! Back to the drawing board. Thanks for the help.
    Self built
    Gigabyte P35-DS3P
    motherboard
    24" Gateway LCD
    1920x1200
    Apevia X-Cruiser
    4 80mm case fans
    Saitek Eclipse
    15Mb/s FiOS
