Screenshots and Files - Upload and Post in Vista Forums
How to Upload and Post a Screenshot and File in Vista Forums
This tutorial will show you how to upload, attach, and post a screenshot, image, or a file in your post here at Vista Forums.
CONTENTS:
OPTION ONE
To Insert Image into Post
1. Do step 2 or step 3 below for how you want to insert an image into your post.​
2. Drag and drop the image from your computer to where you want into your post, and go to step 8 below. (see screenshot below)​
3. Place the cursor in your post where you want to insert the image at, click/tap on the Insert image (Ctrl+P) button on the toolbar of your post, and go to step 4 below. (see screenshot below)​
4. Do step 5 (drop) or step 6 (click) below for which option you want to use.​
5. Drag and drop the image from your computer into the Drop Image box, and go to step 8 below. (see screenshot below)​
6. Click/tap on the Drop Image box. (see screenshot below)​
7. Browse to and select the image you want to insert, click/tap on Open, and go to step 8 below. (see screenshot below)​
8. Select the now attached image in your post, and select if you want a Thumbnail (recommended) or Full image version of this image. (see screenshot below)​
9. If you want to add a link to the image, then click/tap on the image in your post, and click/tap on the Insert link icon. (see screenshot below)​
A) Type the URL address you want for the link, and click/tap on Insert. (see screenshots below)​
10. When you are ready to submit your post, click/tap on the Post reply button. (see screenshots below)​
OPTION TWO
To Attach Files to Post
1. Click/tap on the Attach files button at the bottom left of the post box. (see screenshots below)​
2. Browse to and select the file you want to attach, and click/tap on Open. (see screenshot below)​
3. Do step 4 (file) or step 5 (image) below depending on what type of file you uploaded to attach.​
4. If you uploaded a file, you will now see it listed at the bottom. Go to step 6 below. (see screenshot below)​
5. If you uploaded an image, place the cursor in your post where you want to insert the image, select if you want a Thumbnail (recommended) or Full image version of this image, and go to step 9 in Option One above. (see screenshots below)​
6. When you are ready to submit your post, click/tap on the Post reply button. (see screenshots below)​
Hello Shawn awesome tutorial. This will be a lot of help for newbie's as well as members. Great work
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
Thank you Tom. :)
Tutorial now updated. :)
