SD Card Problem
grammakim4
SD card problem, I purchased a digital photo frame and it only takes the SD cards put pics are on computer, when I go to save the pics to the SD card it doesnt give me the option to use it. I wont show up at all. Help pls
1) It matters what device you are using to connect your SD card to your computer.
2) If the SD card you bought was an SDHC [SD High Capacity] card it could have compatibility issues with the device you are using to connect the card with your computer.
Please give more information and I'll try to help.
-DirtyData
    Me
    Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache LGA 775
    Foxconn P45A-S LGA 775 Intel P45 ATX Intel
    OCZ Fatal1ty Edition 4GB 240-Pin DDR2 SDRAM DDR2 1066
    MSI N9800GT 512OC GeForce 9800 GT 512MB 256-bit GDDR3
    On-Board
    Hanns·G HG-281DPB Black 28" 3ms Widescreen LCD HDMI Monitor 500 cd/m2 800:1
    1920 x 1200
    SAMSUNG SpinPoint T Series HD501LJ 500GB 7200 RPM SATA 3.0Gb/s
    BFG ATX12V 2.2 650Watt
    Logitech 904353-0403 Gray 3 Buttons 1 x Wheel USB or PS/2 Wi
    Microsoft Natural Ergonomic Keyboard 4000
Hi grammakim4 and welcome to Vista Forums :party:
Is the card being recognised by the computer? If not, it could be that the card reader cannot recognise it, particularly if the card is SDHC as opposed to SD. You can buy external SD card readers that can utilise this type of card - indeed some SDHC cards are supplied with such a USB reader. If it is an internal reader, and is supposed to be able to read these cards, then check for any loose connections.
Another point - SD cards have a lock switch to prevent overwriting of data already on the card - check this.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Does the photo frame have any type of USB connection?
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Wow I feel real stupid.... ok I have a HP Pavilion Slimline s3020n PC and at the top there are several different ports to use and only one works. I bought a Lexar 2 gb SD card and when I put it in the slot the little green light comes on but I can not find it any where on the computer. I have never used this feature before on my computer. I used to have a lexmark printer that I used but I no longer have it.
I went to device manager and found the slots listed under portable devices. So I know it is on the computer just cant find it anywhere. Any help will be wonderful.
I need the pics off the computer to put on the frame for a show. Thank you Kim
Look in Disk Management for it.
If it's empty you may need to format it first before Windows will show it in Explorer.
It should show up as another disk or mass storage device.
    Intel Q6600
    ASUS P5K MBoard.
    4G OCZ PC2 8500 Platinum
    EVGA 8800GTS Vid Card
    500G Seagate SATA 200G Seagate SATA 100G WD Caviar SATA 80G WD Caviar IDE
    OCZ Elite 800W PSU
    RaidMax Smilodon Case
    Lite-On dual layer DVD burner X 2 Dos 6.2;Win2K;XP; & Vista Ultimate 64Bit.
Found in under Disk Management as "I" tried to save to it said needs to be formated did I want to do this and I said yes and then it told me that it could not be formated.
Any suggestions???
I have tried to format this SD card every way I know how and it wont format the card. says: Windows unable to format. The frame only has this card slot so I have no other way to get the pics to the frame. Pls anyone help, i am very limited on knowledge on this so pls explain. I also went to Disk Management and played there, that is where I see the card when I insert it. It doesnt giive me the option there to format. any suggestions would be greatly appcreiated at this time as I need them before Friday. Thank you in advance for anyone that can help.
Make sure the card isn't locked.
    Acer
    Q6600
    BFG9600gt
    XFI Extreem Music
    Acer X223W
