Select Files using Check Boxes
How to Select Files Using a Check Box in Vista Windows Explorer
This will show you how to turn on or off the option to select a file or multiple files in Windows Explorer with a check box. This is turned off by default.
The usual default way to select multiple files is to either right click and drag a highlight over them or press and hold the Ctrl key and click the files to highlight them.
EXAMPLE:
1. Open Folder Options.
2. Click on the View tab. (See screenshot below)​
3. To Turn On Check Box Selection
A) Check the Use check boxes to select items box. (See screenshot below step 5)​
4. To Turn Off Check Box Selection
A) Uncheck the Use check boxes to select items box.​
5. Click OK to apply and close properties.​
How to Use the Check Box Selection
1. Open a Explorer window to where you want to select files.
2. Highlight the file you want to select and check the box. (See screenshots below)
NOTE: Repeat until you have selected all the files you wanted.
3. Now perform whatever action you wanted to do with the selected files.
NOTE: EX: Move, Copy, Delete, Etc..
Your welcome neocyprinus and mafia boy. I'm glad that you like it.
