Serial numbers
Hello Sammy,
If you still have your Vista Home Basic installed and activated with your key number, then you can use the program below to retrieve it from within Vista.
http://www.vistax64.com/tutorials/85023-product-key-number.html
If you have a OEM (store bought) computer then the key number will be on a sticker on the bottom (laptop) or back (desktop case) of the computer.
Asking for a product key number is not allowed since this is advocating piracy. It will get you permanently banned, so do not ask for one again.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
