Solved Serious help needed!
rjay90
Hi all, new to these forums so sorry in advance if this is the wrong place to post this, but as title says, serious help needed.
Ok to start with im running Windows Vista Home Basice Off of a Compaq presario CQ40 Notebook PC(if that helps at all :S) 32-bit OS.
Ok now for the problem.
I was using my comp on wireless internet, turned it off and when i came back to it my firewall all of a sudden was busted. I have gone into Windows Security Centre and it comes up with the four options, Firewall, Automatic Updating, Malware Protection and Other Security Options. Now Firewall says Off. Automatic updating says Off. Malware protection says Check Settings, and Other is OK!. Now I click on the option under firewall to turn it on and it comes up saying Security Centre can't turn on windows firewall. Now underneath that it says turn it on manually, so i click that and i get another screen with a warning box saying "Windows Firewall is not using the recomended settings to protect your computer.
To the right of that there is an update settings now button, i click that and im sent to a Windows needs your permission to continue screen where i select continue. Now i get a screen saying Windows firewall was unable to make the requested updates.
Also since this has happened my Optus wireless internet wont connect which means no internet access on that notebook, and now my iphone is not detected by itunes...
Im seriously about the chuck this ******* thing out the window.
Also it wont let me manualy change any of the setting in the services section and also will not let me open the event log.
Please tell it is fixable, oh and im using an updated AVG, scanned full computer no viruses.
Hopefully someone out there has an answer to my problem or is able to help me along
Thanks in advance to anyone who can help me
try start\all programs\accessories\command prompt\
Right click and run as administrator
Type SFC /SCANNOW note the space after sfc Also download and run Malwarebytes
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
Thanks for the reply mate, tried inputting that into command prompt and downloading that file, still having the same problems though
No malware found? Hmmm.
Have you tried to do a system restore?
    Inten Pentium Dual Core E2180
    1 x 2GB Kingston 667. 1 x 1GB Kingston 667
    256MB GeForce 7300LE
    Realtek HD 6.1 Audio
    Dual Monitor - 1 x 22" LG W2242T | 1 x 15" Proview
    1680 X 1050
    1 x 250GB Samsung ( Internal ) 1 x 500GB Hitachi ( Internal ) 1 x 320GB Western Digital ( External )
    A4Tech G6 Wireless Mouse
    Logitech Media Wireless Keyboard
    DL : 12MB/s | UL : 1.2MB/s
@rjay90: Please do not repost the same query in different sub-forums as it makes it very difficult for both you and us to keep track of it. I have removed those posts, so please use this thread for your problem.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
Sounds like you have some mal-ware on your laptop. AVG wont always find that.
look for Malwarebytes org, I think. Download their anti-malware, you may have to use another computer, put it on CD, install in safe mode, run it.
    Acer Aspire X1700
    ASUS
    3 gigs
    EVGA 1 gig GeForce 210
    Vizio 21" tv
    1920x1080 resolution
    fans that came with it
    basic USB
    basic USB
Thanks to all who replied to help me out, winner was just a simple system restore and everything looks to be in order :) now i can finally do some work, cheers to all.
