Serious problem going from Vista to XP
Ryan016
Hi all,
I have a Sony Vaio Laptop, and want to "downgrade" to XP!
I have completely formatted my hard drive, and set my laptop to boot from CD. It starts loading drivers etc but after about 3/4 mins it says that it cant find a hard disc to install to???
Im guessing im doing something seriously wrong, ANY help would be great as im not Laptopless.....sigh
Check you bios. It sounds like you may have inevertently turned off the HD.
What type of FAT did you use for XP, Vista uses NTFS and XP uses the FAT file system.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
AHHH just looked and i was wrong its NTFS, when i go to do the install though it only gives me two options 'Format the partition using the NTFS file system' or 'Format the partition using the NTFS file system <quick>'
How do i re-format as FAT???
i used to use this one Format the partition using the NTFS file system when i used to format ..but i dont know about others they might give better adivce but thats what i used to do :)
    I5 3570K
    Gigabyte Z77-DS3H
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Yeah i use the XP CD to format the Hd and it does that fine, but when it starts to install it says it cant find a HD to install to.
I have tried connecting removable storage too, it finds it but then says it cant install on it...
Hi Ryan,
What is the full model number of your laptop?
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
theres a lot of people 'downgrading' and figure out that some of the settings wont let you. i think it was my sata drive that wouldnt let me install cause it didnt 'see' the hd ..and i know it did in Vista .lol im just rantng today.
    Gateway ML6437-est. laptop
    Intel (R) Pentium(R) Dual CPU T230 @ 1.86GHZ /1.87 GHz
    factory installed/user customized
    3 GB
    onboard
    onboard
    onboard
    320gb wd caviar
    factory
    factory chassis
    factory
    touchpad factory
    factory
    AT&T DSL
    currently certified as the fastest computer in the city of 38761
