Solved Set associations control panel
patch41
Vista Pro
hi, when i try to play an avi file that i recieved in a e-mail, a pop up box tells me, this file does not have a program asssociated with it for performing this action, create an association in the associations control panel. can anybody tell me where the associstions control panel is and how i go about it,i have windows vista 32-bit,thank you
hi shawn, you came through again for me, i followed the clear step by step instructions on how to restore default vista file extension type associations and it worked like a charm,a big thank you from me...patch41
Also you can do stuff like open one of the Media Player Classic or other players and select individual formats. I have Media Player Classic Home Cinema 64 bit associated with .avi but if I want to play an .avi with VLC Media Player, I have VLC in the SendTo menu.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
You're welcome Patch. I'm happy to hear that you got it sorted. :)
