Severe Problem
soapface
Hello, I recently wanted to update my Anti Virus Program named Kaspersky.
I was trying to update my 2011 version to the 2012 version.
I inserted the Kaspersky Disc during my computer startup, it than took me to Install Kaspersky, I entered all the details like Language, ect. After I entered it, it started to install/update. Now while it was installing/updating I've accidently hit the Open tray and Reset button!
So the disc tray opened and my computer restarted while it was installing/updating. It started up again, and I went back to the Install disc again. After going through the options again, it showed the Kaspersky window and up the top in red it said "Databases corrupt". I tried re installing it again but it is still saying that it is Corrupted, I tried roll back, but that didn't work either. So I just decided to exit it and go to my desktop.
I restarted my computer and took the disc out, after a minute or so I got a blue screen saying "Windows shut down to prevent damage to your computer" and it said something else saying "Disable or uninstall any Anti virus, disc defragmentation, or backup utilities".
I got out the Windows Vista disc and put it in, restarted and loaded the disc. I went to "Repair my computer" then "Repair startup files" After a while it finished, I restarted. I didn't get the blue screen, but instead I just got a black screen with my cursor on it. I can move it around and nothing else, I cannot bring up taskmanager by going CTRL+ALT+DEL or CTRL+SHIFT+ESC. I tried tapping SHIFT 5 times for that BEEP and the message that pops up, but still nothing.
I then restarted AGAIN, and something else came up. It said two things:
Windows Vista
Windows Vista Home premium (Recovered)
I went to the "Windows Vista Home premium (Recovered)" option and the computer loaded up perfectly, the desktop showed up, Internet worked, all working, right? Well it didn't, I went to My Computer and the C: drive didn't show up, only my other drives, and the C: is MY most IMPORTANT drive on my computer, I needed it with all the Work, information stored on it.
I restarted again and went to the "Windows Vista" option, and that was the not working one, it came up with the Black screen and cursor, so I assume it is the one with C: drive on it.
I went back to the Repair my computer, and went "Repair startup files" again. It finished, and I checked the logs of it. At the bottom of it it said "Registry files corrupt".
I than went to "Command Prompt" in the repair my computer and typed "C:" and then "regedit" I went through the files until I got to System32 config folder, there was a backup folder and it had the backup files within it. I replaced the corrupt files (The System, Software, Sam, and Security) with the backup ones. So then, I went back to the repair my startup files. I checked the logs again and it said successful, and up the top it said "Windows found nothing wrong with your computer".
I restarted and STILLLL the black screen with cursor!
I'm out of ideas I don't know what to do, please help!
Hello.. good lord man.. I have never seen an issue get worse trying to repair it.. You seemed to have followed steps that would have fixed this. Except a clean Install . If you did have anything important . try this first : Use Ubuntu Live CD to Backup Files from Your Dead Windows Computer - How-To Geek Post back if you can save any of your important stuff.. Then if that works. means your hard drive should be okay. If so . you could try this : http://www.vistax64.com/tutorials/117366-clean-install-full-version-vista.html
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
I got that black screen with the cursor on my Win 7 machine the other day after I had done a system recovery.
Afterwards, I was installing some software updates and, next thing I know, something is replacing all the SIDs (192,000+) on my system with the default ones. Not knowing what it was, I stopped it and rebooted. Got that black screen with the cursor. I could Control Alt Delete to get to Task manager but as soon as I clicked on anything, back to the black screen.
I shut down and ran chkdsk. It replaced all the SIDs. I shut down and let it sit for a few minutes. When I rebooted, everything was fine and has been since then.
I think my problem with the SIDs was related to the system recovery but, maybe you need to run chkdsk.
I'm curious why you are installing Kaspersky during the system boot. Doesn't seem necessary. Maybe I'm misunderstanding.
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
