You should upgrade or use an
alternative browser .
Solved Shortcut image problem
Just recently my shortcuts all have a broken link image where the little shortcut arrow would appear. Any ideas where or how to fix this?
45.7 KB
AMD 64 X2 6000+ @ 3.15Ghz
ASUS CROSSHAIR 570 SLi
8Gb DDR2 G.Skill 6400
NVIDIA GeForce 8800 Ultra
Creative X-Fi
Hanns-G HN199D
1280x1024 @ 75Hz
1 x SATA WD 300Gb
1 x SATA Seagate 750Gb
Apevia 680W
Antec 900
5 x 120mm; 1 x 200mm; 3 x 80mm
HP Wireless
HP Wireless
9Mb/s Cable Wireless N
LG Blu Ray/HD DVD drive
Hi BigEasy,
It looks like you may have used the XP method to remove or change the shortcut arrow instead of the Vista method.
You can use the program in this tutorial to select and restore the normal shortcut arrow. Afterwards, you can make any changes you like to the shortcut arrow or remove it.
http://www.vistax64.com/tutorials/67615-shortcut-arrow.html
Operating System
1TB Samsung 990 PRO M.2,
4TB Samsung 990 PRO PRO M.2,
TerraMaster F8 SSD Plus NAS
Galaxy S23 Plus phone
Operating System
Thanks that solved my problem
:D
Creative X-Fi
Hanns-G HN199D
1280x1024 @ 75Hz
1 x SATA WD 300Gb
Apevia 680W
Antec 900
HP Wireless
HP Wireless
Your welcome BigEasy.
Operating System
Operating System
