Should I Get 64bit or 32bit?
2-D
I'm not sure which will run better on my system. I hear 64bit supposedly runs programs faster then 32bit does.
i'm planning on getting vista ultimate.
here are my specs
2gb ddr2 ram
nvidia 8500
2.2ghz intel core 2 duo cpu
Asus P5GC-MX/1333
creative soundblaster audigy 2 zs
Also, I play a lot of video games, i'm not sure if that would conflict with anything, and I also use a lot of programs (not specifically at once), though i heard 64bit can emulate 32bit only programs.
    Asus P5GC-MX/1333
    2gb ddr2 ram
    nvidia 8500
Hello 2-D,
If you have 64 bit driver versions available for all of your devices, then I would recommend that you use the 64 bit Vista. This way your computer can actually use more than 3GB of RAM if you decided to add more later. The 64 bit Vista can run both 32 bit and 64 bit programs without any problems.
This article will help explain the differences to:
http://www.vistax64.com/vista-news/99613-64-bit-more-than-just-ram.html
I was planning on getting 2 x 2gb sticks of ram anyways.
And I checked, and they all have 64bit drivers which is nice.
    Asus P5GC-MX/1333
    2gb ddr2 ram
    nvidia 8500
yes get 2x2gb ram. I made the mistake of getting 2x1gb so i ended up filling my ram slots with only 4gb.
ive not had one problem with anything running on 64 bit, infact i dont think ive had any problems whatsoever with windows.
    §ĮŁΣNŦ Д$$Д$$ĮN
    Xeon X3360
    P5W64 WS Pro
    EVGA Geforce GTX470 SC+
    Samsung T200
    WD 1TB RE3
    Thermaltake Toughower 750w
    NZXT Lexa Silver
    Zalman CNPS10x Extreme
    Razer Deathadder 3500dpi
    Razer Lycosa Mirror
    24Mb/s
I'd go for 64bit. I was previously on 32bit but since I've changed to 64bit I've noticed some great performance increase. I don't think I'll ever go back.
    Self Made System #1 2004
    Intel Pentium 4 650, 3566 MHz
    Asus P5LD2 Deluxe
    2048 MB (DDR2-533 DDR2 SDRAM)
    NVIDIA GeForce 8800 GTS (640 MB)
    Realtek ALC882/D/M @ Intel 82801GB ICH7 - High
    LG L204WT (Digital) [20" LCD]
    1680 x 1050
    [XP (160 GB, 7200 RPM, SATA-II) 8M] [Vista (320 GB, 7200 RPM, SATA-II) 16M] [Storage (500 GB, 7200 RPM, SATA-II) 32M]
    E-Power 570W Power Supply
    Antec SLK1650 Beige Mid Tower ATX Case
    Zalman CNPS9500 LED CPU Heatsink
    Microsoft HID-compliant mouse
    Logitech Standard 101/102-Key or Microsoft Natural
    Max 700 kbps Down / Max 90 kbps Up
    Coming Up --> Self Made System #2 MID2009
I have almost all apps migrated to x64 and love it, although I would recommend 8 GIGS of ram, and forget the incremental steps. .. Vista x64 loves 8 GIGS of Ram. . .
sportsguy
    Core 2 Duo 6600
    ASUS P5B Deluxe
    8 GIGS Corsair C4DH
    EVGA 8600 GTS
    Dell P990
    WD 250 G DiamondMax 250 WD 500 x 2 Raid 1
    Antec 650
    Thermaltake Armor Full Tower
    Zalman ZNPS 9700
    Office 2007
