side by side configuration error
lukeroberts
hey guys ive been getting a side by side configuration error when i try to play dead space and when i try to use the new msn messenger. it all came all of the sudden i had the new messenger on my windows 7 beta and it was worknig fine put it on my vista 64 and down she went with this strange error. dead space i had played once (it was working fine on 32 bit) but after i went to start it again i got the same config error.
ive reinstalled all of the programs numerous times updated my visual c++ and so on but i dont no wat to do, this gives me no error number and ive never heard of it or seen it before.
please help me with this irritating problem:sa:
    ME Model #lukeroberts
    AMD Phenom II x3 720 Black Edition
    Gigabyte / XFX
    6 GB/3 GB
    ATI Radeon 4870
    25.5" Viewsonic / 19" LG / 17" NEC
    1920x1200
    500 GB Seagate Barracuda x3
    Rocketfish(lol) 700w SLI
    Logitech G11
ok so i solved the problem and heres how to fix it incase anyone else encounters it.
go to the visual studio 2005 or 08 or watever your program requires folder in side your programs directory. in my case for dead space, it was under the "redistributables" folder in my game directory. reinstall the visual studio exe inside of there and it should all restart
the fact i didnt try that right away makes me feel a little dumb :P but i can see it being easy to overlook, especially when you look all over the internet and all the answers tell u to download ridiculous amounts of things or just reinstall your program :geek:
    Gigabyte / XFX
    6 GB/3 GB
    ATI Radeon 4870
    1920x1200
    Logitech G11
I am havingthe same problem, I am not very good with computers... But, I read about installing that Visual C++ 2008 only trouble is it gives me the same side-by-side compatibility message when I try to run any an all none 64 bit programs.
    Dell XPS M1530
I am getting the side by side when I try to download anything that is pdf. I have uninstalled and installed again and it does not help. Any thoughts
I'm using windows vista and after downloading and installing one of window's lastest updates for the system I started receiving this side-by-side error. I know enough about computers to be able to follow directions if they're in layman's terms, unfortunately most of the help I've found through google goes way over my head.
After the last update I can't get yahoo messenger, windows live messenger, matlab, or my antivirus software to run. Everytime I try to open them I just get another pop up telling me there's a side-by-side error. Any help I could get resolving this would be appreciated!!
There is no ANSWER. The QUESTION is why Microsoft forced an update down our throats that disabled MSN Messenger. Since *I* cant get on, the people I talk to now need to start using a DIFFERENT messenging system. Someone needs to explain to me how driving us to another service is good for Microsoft OR users, cause I'm not "gettin' it".
