side by side configuration is driving me mad!
richrit
ok, so for a while now ive been getting errors which appear to be when i try opening microsoft office , and windows live programs.
For office, when i try to open a file from computer, or open the program itself, it comes up with this: "this application has failed to start because its side-by-side configuration is incorrect. Please see the application event log for more details".
This is what it says in the event log: "Activation context generation failed for "C:\Program Files\Microsoft Office\Office14\EXCEL.EXE.Manifest". Dependent Assembly Microsoft.VC90.CRT,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.30729.1" could not be found. Please use sxstrace.exe for detailed diagnosis."
Now when i try to open a windows live program such as windows live messenger, i get the same side by side error message, and the event log brings up this: "Activation context generation failed for "C:\Program Files\Windows Live\Messenger\msnmsgr.exe". Dependent Assembly Microsoft.VC90.CRT,processorArchitecture="x86",publicKeyToken="1fc8b3b9a1e18e3b",type="win32",version="9.0.30729.1" could not be found. Please use sxstrace.exe for detailed diagnosis."
Please if anyone could help, i would really appreciate it. ive tried system restore, defragmenting, re-installing the programs, registry cleaner, and still, the problem hasnt fixed.
many thanks in advance
    Vista Home Premium 64 bit SP2
    Cyberpower
    Intel Quad CPU Q6700 2.67 GHZ
    NVIDIA 780i
    MSI GTX 560 TI Twin Frozr
    Sound Blaster SB Audigy
    Viewsonic VG2436
    1920x1080p
    Samsung HD 105SI WDC WD20
    Apevia XJupiter
    air
    Logitech MX 600
    Logitech MX 3200
    30 Mbps
