Lorien
Account Suspended
I've noticed since I switched from my last forum where I had 12 open IE8 Windows at the same time (each with multiple tabs - there I needed a separate window for each individual forum because of how things worked), Outlook, Word, and perhaps several other programs and had memory usage around 40-60% (I only have 2GB which is all my motherboard can handle), that when I put my computer to sleep, when waking up again it was as slow as molasses to the point where I needed to restart within a matter of minutes because it was intolerable.
Now using IE9 and having only one open IE9 window (with a few tabs) and essentially the same other applications, memory usage is around 10-20% and when I wake from sleep mode it starts up immediately and I have no problems whatsoever. So it seems that memory usage (or the change to IE9 - but probably the memory more) makes a huge difference in how it functions (and whether it functions properly).
I thought I'd mention that for anyone with anyone who's got someone having problems with waking from sleep. Be sure to check on memory utilization when the computer is put to sleep as it may be the cause and, if reduced before putting the computer to sleep (in my case, if I had closed all the IE8 windows perhaps), maybe the wakeup problems will be resolved.
This, of course, makes sense since sleep mode uses RAM to store information so if a lot of RAM is already being used, there isn't much left for sleep mode information and when you wake you find you're close to 100% utilization which naturally grinds you to a halt.
I also discovered that each IE8 window was taking 8-12% utilzation from time to time - so sometimes even during the middle of the day I would max out and needed to close all IE8 Windows and start over (and even though I re-opened all the same windows again, it didn't use the same amount of memory and I was back down to 50-60%). With IE9, I'm finding each instance takes 0-1% utilization. I don't know if it's a difference in the forums or a difference in IE, but it's quite a lot better. I think it's perhaps a little of both, but that IE9 does use less resources.
Anyway, I thought I'd share that with everyone in case it helps. Perhaps it's just a fluke with my system or differences in how many IE Windows I have open at one time (or maybe it does have something to do with IE9), but whatever, things are much better now and sleep mode functions perfectly again and I'm very happy about that.
P.S. There's a thread here http://www.vistax64.com/vip/279014-more-help-requested.html that I think we could all use from time to time and apparently something similar seems to be a big hit in SF. It's a way to request help from others if you're stuck with a problem in a thread without needing to message friends individually for assistance. This way everyone sees it and anyone who's available can pitch in to assist. We all get in such situations from time to time and everyone else assume we have it covered and often ignores the thread when in fact we really could use some assistance. This has happened to me a couple of times recently and I have yet another one that's very close to being the same. I've at times even gone so far as to post the questions in other forums for assistance - but I think all the help I really need is already here.
I think this is a way we can help each other out when we run out of ideas or things become more complicated than they originally seemed (maybe we just started by asking questions about the problems and the answers revealed a situation much more complicated than it seemed at first because the original post was too vague - or maybe we've tried all the solutions we know and researched for an hour or more and still come up with nothing useful). I intend to try using it myself if needed and I will try to help if I see someone else has posted there.
Best wishes to all.
Best wishes to all.
- Dell Inc. MP061 Inspiron E1705
- 2.00 gigahertz Intel Core 2 Duo 64 kilobyte primary memory
- Board: Dell Inc. 0YD479 Bus Clock: 166 megahertz
- 2046 Megabytes Usable Installed Memory
- ATI Mobility Radeon X1400 (Microsoft Corporation - WDDM) [Di
- SigmaTel High Definition Audio CODEC
- Generic PnP Monitor (17.2"vis)
- 1920 x 1200 pixels
- Hitachi HTS541616J9SA00 [Hard drive] (160.04 GB) -- drive 0, s/n SB2411SJGLLRMB, rev SB4OC74P, SMART Status: Healthy
- Case
- Chassis Serial Number: 5YK95C1
- Logitech HID-compliant Cordless Mouse
- Standard PS/2 Keyboard
- 1958 Kbps download ; 754.8 Kbps upload
- Other Info
- Optiarc DVD+-RW AD-5540A ATA Device [CD-ROM drive] Dell AIO Printer A940 Conexant HDA D110 MDC V.92 Modem 6TO4 Adapter Broadcom 440x 10/100 Integrated Controller Broadcom 802.11n Network Adapter Microsoft ISATAP Adapter Teredo Tunneling Pseudo-Interface Router Linksys / WRT54G -01
