Slow speed Between Computer and Router
DjLevel9
Banned
did a cmd tracert <space> yahoo.com
my computer to my router 48 ms according to my internet provider he says thats high is there a way to reset this and fix this?
I have a Speed Touch 585 Router and the Firm ware update date is up to date i one if all the setting i did to help me here restting thing's in my regit edit screwed up some how ?
I had a very similar problem some years ago with a wireless network card
i had only had it 3 days and i started getting loooooong response times, i kept doing speed checks via Speed Test - dslreports.com and the 1 thing i noticed every time was a very high latency
i googel for a while to learn a little about latency only to find out that it is something that cannot be fixed with. i.e firmware - driver updates ect
[latency can also come from your isp, so best to check with another pc b4 you panic]
so i took the card out and got a refund and bought a new card of a different brand and hey presto no more problems
now not to say this is your problem but could be the answer
good look
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech MX Revolution
    Logitech G15 (full layout)
The latency from the OP's computer to his local router cannot be affected by the ISP. That's just ignorant to suggest. I will say that 48ms is rather high latency for a zero hop connection. I would expect something in the 1ms to 2ms range, maybe 3ms at the most.
How do you connect to this router? I sure hope it is WiFi and not direct connect.
S-
    Intel E6600 @ 3.0 GHz
    EVGA nForce 680i SLI (NF68-A1)
    4GB - CORSAIR XMS2 PC2 6400
    EVGA GeForce 8800 GTS (640MB)
    2 - Seagate Barracuda 7200.10 (320GB) 1 - Seagate Barracuda 7200.10 (500GB)
