Solution to Diagnostics Policy Service not starting
Hello,
This is a solution not a question.
It took me hundreds of manhours and I hope it helps other people.
Problem: In Windows Vista, The DPS (Diagnostics Policy Service) (in Greek: Υπηρεσία πολιτικής διαγνωστικών) does not startup either by right clicking on the network tray icon and selecting "Diagnose and Repair" (Διάγνωση και επιδιόρθωση) or by trying to start it directly from the Services panel. To get the exact error message, go to Services and try to start the service from there. This is a combination of two errors: 1079 ("The account specified for this service is different from the account specified for other services running in the same process") and 5 ("Access denied").
First error:
Error 1079 (The account specified for this service is different from the account specified for other services running in the same process).
Solution:
1. Click Start, type "Services.msc” in the Search programs and files box, and then press ENTER,
2. Locate and double click the Diagnostics Policy Service (Υπηρεσία πολιτικής διαγνωστικών) service.
3. Click the Log On tab,
4. In the This account text box, type “NT AUTHORITY\LocalService”,
5. Set both Password fields blank,
6. Click Apply and then OK
Try to start the service and you get the second error.
Second error:
Error 5 (Access denied). Cause: The service is trying to access C:\ but LOCAL SERVICE account is denied access.
Solution:
1. Right click on local drive C:\ and select Properties
2. Go to the Security Tab
3. Add LOCAL SERVICE to the user list and assign Full Control priviliges.
The DPS will start fine now and if set to automatic start mode it will never trouble you again.
    Dell Inspiron 1525
Good tip, and very well written, thank you.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB Seagate ST2000NM001 2TB Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot) Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
Hello,
First error:
Solution:
Second error:
Solution:
[h=1]Diagnostics Policy Service not running[/h]
10/13/14
Thank you for the report but that did not fixed the problem on my system. Your suggestion was helpful but there were cautions and warnings when I was using your protocol. I continued to search other forums and below is the fixed that worked for me first time out and the problem has not come back. I believe this problem happen due to a blue screen that I received after unplugging an iPhone from my locked up system. Afterwards the system ran a scan disk and I had 50 corrupt files. The on-board PC repair fixed all of them except this file. Could not get on the internet. With these two lines of code the problem is fixed. Pass it on. Thank you.
go to start ,search and type:- cmd, right click on returned cmd.exe and select "run as administrator" at the prompt type:-
net localgroup Administrators /add networkservice
press enter then type:
net localgroup Administrators /add localservice
exit
press enter and restart your computer
Open services and make sure the service is started.
    DELL E310
    Pentium 4 HT 2.8Ghz
    2GB
    NVIDIA FX5200 250MB
    DELL 19"
    1440 x 900
    2-160GB
    Tower
    50Down 10Up
exit
Please note that this provides those accounts with full administrator access and therefore raises security concerns. If security is important I do not recommend this especially on servers. Those accounts should be left alone.
    Windows 7 Pro & 10 Pro
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB & 500 GB
