sound help please
iammrj
Over the past week I have been trying to fix a sound problem that seems to incurred after an update (unfortunately i dont know which one!)
I have lost surround sound via my headphones so therefore voices and sounds in games are either stereo, completely dissapear, gun sounds are very tinny and footsteps are impossible to distinguish which direction they are coming from
I have updated to all latest drivers but that hasnt helped at all
Useful information for you guys is I have a AC-1 Sound Card running on vista 64 bit
So frustrating!
Also if it helps:
* I have tried completely removing ac1 sound drivers and reinstalling
* If I run from the onboard VIA audio its still exactly the same
* DXdiag detects no problems
* Speakers instead of headphones do exactly the same
* Online audio is also very tinny (terrible) and music I have on HD
* I have checked windows updates
Hi Iammrj
I assume you're using Vista.
First thing you can do is to open Control Panel from the Start Menu,
and then click Sound, (Tab Play should be open).
Double click the active sound device (mine is Realtek Digital Output)
You should now see a window called "Properties of Realtek Digital Output"
Click on the Enhancements tab.
Here you can choose different audio options.
Maybe there are settings changed by the update, (Or Windows, in a weird mood, has changed the settings)
I suggest you do some experimenting with the settings,
to see (hear) if you can get some improvement.
It is possible that other members on the Forum can offer a better solution.
So if the suggestion above does not work,
maybe someone else could provide a better solution.
Success
Sweet
    Acer Aspire 5738G-644G32MN
    Intel Core 2 Duo - clockspeed 2000 MHz
    Acer JV50
    RAM 4 GB - SO-DIMM DDR3
    NVIDIA GeForce - G105M - 512 MB
    1366 x 768 Pixels
    Hitachi HTS543232L9A300 320 GB - Type SATA - Speed 5400 rpm
    Logitech Wireless Mouse M505
    Azerty
    Currently 14.5 MB/Sec which means 1.8 MB/Sec effective
Hi Sweet
Sorry yes its Vista Home premium 64 bit
I will have a look when I get home from work but from what I remember in control panel-sound-devices there is only the AC1 HD audio and the VIA HD audio, I'm almost certain there is no Realtek Audio (maybe thats the problem)
I have had a play with the various settings and nothings seems to improve at all
What is really strange is that Youtube videos, the sound is fine 30 seconds then goes terrible
, there is also no clearly defined left and right speaker sound when I test it
Whats also bizarre is that Vista has seemed to take longer to load up since this problem, it gets stuck on the screen before you enter your login for about a minute
My systems is
core i5
320gd Hitachi SATA II
4gb Corsair Dominator RAM
5870 Graphics
Asust P7P55D - PRO motherboard
Hopefully this helps
I would start by making a back up. Then go into your (Add/remove programs) *Programs and features* and select the last update you installed. and repeat the process until the system is back the way it was. Then once you have found the bad egg write down the KB number and DO not install that update :D I have had that issue happen to me several times. Especially while using windows automatic updates. I won't reccomend you to not use automatic updates as everyone uses their pc's differently. But I do suggest that you at least change it to let you review the updates before installing them.
    Amd Phenom II x4 965 BE rev.C2
    MSI ms-7599
    A-DATA DDR3-1600G PC3-12800 4GBx2
    Biostar NVIDIA GeForce 9400GT mn: VN9402THG1
    Creative SoundBlaster Audigy 2 Zs
    Compaq FS7550 (D-SUB)
    1600*1200
    Western Digital WD10 EADS-00L5B1 SATA (1TB) (Main drive) Hitachi HDS721010CLA332 SATA (1TB) (Secondary drive) Samsung HM250HI SATA (250GB) (Music and swap) Western Digital WD800BB-75CAA0 IDE 133 (80GB) (misc)
    RAIDMAX RX-850AE 850 Watt 12x4 rail 80plus gold PSU
    Cooler Master RC-430-KWN1 (elite 430)
    Corsair Hydro Series H50 (*120mm (x1))
    I Home Lazer
    Standard Microsoft (500)
    around 4 Mb a sec
    CD-rom's TSSTcorp CDDVDW SH-S223L SATA (Samsung) HL-DT-ST DVDRAM GH22NS40 SATA (LG)
