Up until a couple days ago my home network and Internet access were all working great; Then I decided to get rid of Ubuntu on my HP desktop and have Vista Home Premium x64 as my only OS. Needless to say, that involved a host of problems, including reinstalling Vista just to get the stupid Vista boot loader back. Vista is up and running again, service pack 2 and all updates installed. Yet the network connection is being.... strange. After much tinkering and getting help online, I thought I had solved it... all my computers are talking again and happily chatting away with the Internet. Yet the HP in question doesn't stay that way. Here are my symptoms:
1. Browsers cannot connect to web pages (both latest versions of Firefox 3 and IE 8)
2. Network connection icon on taskbar remains blue, as if connection is great, yet nothing happens when I hover over it or click on it
3. Trying to open up "Network and Sharing Center" through the control panel freezes Windows
4. Trying to access other computers on my network from my HP gives me the "Network path not found" error. Cannot access HP through the other computers, either.
5. Perhaps unrelated, but computer won't restart - I must fully shut it down, then manually turn it back on. When trying to restart, the computer shuts down normally, then the power stays on the tower, the light indicating hard drive access flashes, yet there is no image on the monitor.
Everything works fine for about 20 minutes after turning the computer on, then these symptoms appear, so I don't think its my firewall or anything like that - I'm using Kaspersky Internet Security 2009, BTW. My other computers are running different versions of XP, and they have no problems whatsoever. Virus scan turns up negative. I found similar threads, but nothing completely addressing my problems - I tried those solutions, too, with no luck. Any help will be greatly appreciated.
- HP Pavillion a6720y
- AMD Phenom 9550 Quad-Core 2.20 GHz
- NP200AA-ABA a6720y (Not sure if this is correct)
- 6 Gigabytes RAM
- NVIDIA GeForce 9100 (Integrated into Motherboard)
- Realtek Digital Output (Realtek High-Definition audio driver
- Acer X203H
- 1600x900 (32BIT) (59Hz)
- C:\ 600 Gigabytes Lacie 1 Terabyte external (Network Drive)
- Cable
- Other Info
- Kaspersky Internet Security 2009
