Start menu help
In a nutshell though, for most programs/apps, you should be able to right click on them and select "Pin to Start Menu."
And you can add the "Pin to Start Menu" command to your context menu if you don't already have it. Here's how:
How to Pin a Program Icon to the Start Menu in Vista
How to Pin a Folder Icon to the Start Menu in Vista
Initially, to have a folder pinned to your Start Menu, you have to set Vista to allow folders to be pinned to the Start Menu. Afterwards, you can then right click on the C:\Users\(user-name)\folder name folder and click onPin to Start Menu.
    HP Pavillion dv5t (Gen. 1)
    1680 x 1050
    built in - HP
    max
