Solved Start Up Issue
jborchel
My wife's 32 bit Vista laptop on startup or after lengthy idle time occasionally starts a picture player that goes into her Picture Library and plays her pictures one after another full screen. She can usually stop the player by hitting "esc" but not always. Also, I don't see any player controls that are visible on most media players.
The problem is that this often locks up the laptop and she(I) have to reboot/restart any way I(she) can. I suspect some kind of virus like program that someone has slipped in there that does this. I went through the msconfig/startup file and could not find anything that looked suspect.
Any advice would be appreciated.
Hi jborchel,
In addition to what richc46 has mentioned, try to change the screensaver settings and check the performance, please use the following link for detailed instructions to change the screensaver: http://www.vistax64.com/tutorials/85539-screen-saver.html
For any clarifications feel free to contact me.
    AMD FX-4100
    Gigabyte
    4Gb
    ATI 5450
    1600*900
    10Mbps
Thanks for all of the advise. I checked the screensaver and it indeed was pointing to the Pictures file on the computer. I changed the setting and hopefully that fixes the problem. Thanks again!
Hi jborchel,
Hope this helped in resolving the issue, please post the results so that it can help other customers also.
    AMD FX-4100
    Gigabyte
    4Gb
    ATI 5450
    1600*900
    10Mbps
