Solved Start up repair problem
Thatslife
Hi
Windows wont start and is asks for the installation disc to fix vista however, my PC did not come with an installation disc, just recovery options (which no longer appear). I've run windows start up repair and get the following message:
Startup repair cannot repair this computer automatically
Problem event name: Startup repair v2
Problem signature 01: External Media
Problem signature 02: 6.0.6000.16386.6.0.6000.16386
Problem signature 03: 0
Problem signature 04: 65537
Problem signature 05: unknown
Problem signature 06: FailureDuringSetup
Problem signature 07: 0
Problem signature 08: 0
Problem signature 09: unknown
Problem signature 10: 1168
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1033
Can anyone help as my pc appears be be caput!
Many thanks
T
Hello T, and welcome to Vista Forums.
What brand is your computer? I'll see if I can find and post back instructions on how to do so from your computer manufacturer's website. Perhaps you could do a factory restore from your OEM recovery partition to reinstall Vista with.
Hi
The option for factory restore dissapeared!
I downloaded a recovery disc and ran that. From that I did a system restire which appears to have solved the problem. I'll look at it this afternoon and post back it I have any problems.
Regards
T
I'm happy to hear that it seems like that sorted it for you. :)
