Static IP / Port forward help please !
Just reset router because i haven't logged in for a few years so forgot password anyway :
Hi i wanna port forward certain things on my router but i need to get a static ip
because if my router gives me a different ip every time my port wont work.
So i went into network connections, local area connection then went to internet protocol version 4 properties.
I ran the command ipconfig got my : Ethernet adapter local area connection info
an i written down my
IP, subnet mask an default gateway
Problem is when i click ok it says the following :
Warning multiple default gateways are intended to provide redundancy to a single network such as (intranet or the internet). They will not function properly when the gateways are on 2 seperate, disjoint networks such as one on the internet an one on the intranet. do you want to save this config
Can someone please help ! thanks :
    Dell
    2.33ghz
    4gb
    NVIDiA Geforce 210
If you have the option associate your mac address with a specific ipaddress within the router. Without knowing more about your router it is hard to tell you how to do it but that is what you need to do.
    Windows 7 Pro & 10 Pro
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB & 500 GB
I can give you more info on my router
Im with virgin media
ive got a netgear wgr614 v9
I have my ethernet from my modem going into the router then an ethernet in the router going into the PC.
i also have an xbox 360 ethernet aswell
Thanks for you help
    Dell
    2.33ghz
    4gb
    NVIDiA Geforce 210
so i find the mac address an then do what, sorry i cant remember what to do as the last time i entered all this info in was a good few years ago but ive just had to reset my router after forgetting the password.
    Dell
    2.33ghz
    4gb
    NVIDiA Geforce 210
First determine the mac address of the device that you use to connect to the internet: How to Find the MAC Address of Your Computer: 19 steps
Second from within the Netgear administration associate that address with the ipaddress that you want. On my Netgear router that is under LAN IP setup. Since you get the ipaddress from your router that is where you set up a static ipadress and not in Windows.
After you are done you will need to do ipconfig release/renew or restart your computer.
    8 gb
    1 TB & 500 GB
