Staticy Sound.
2-D
When I play music, theres a small static sound that comes from my speakers, and its pretty annoying. It doesn't happen all the time, but enough to annoy the hell out of me. Never did this when I had XP, so I know its a vista problem.
It also happens when I scroll through pages, or close tabs, just a little static for the second i do something.
I have a Audigy 2 ZS
I have downloaded the lastest drivers for it, and yes they were 64-bit and for Vista.
If my system specs are needed,
Windows Vista Ultimate x64 SP1
2gb ram
intel core 2 duo E4500 2.2ghz
NVIDIA GeForce 8500GT
    2.2ghz intel core 2 duo
    Asus P5GC-MX/1333
    2gb ddr2 ram
    nvidia 8500
2gb ram
Welcome to the Vista x64 Forums :party:
This Microsoft article talks about sound issues with Vista SP1 and may assist you: You experience problems with sound after you install Windows Vista Service Pack 1
I hope this helps.
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main 500 GB USB External 160 GB USB External 2TB USB External
    DSL 3MB
I'm not having any of those symptoms...
    Asus P5GC-MX/1333
    2gb ddr2 ram
    nvidia 8500
It's more of a 'pop' then static.
    Asus P5GC-MX/1333
    2gb ddr2 ram
    nvidia 8500
I remember when the first longhorn (Vista) betas more than 3 years ago and they had the same problems with sound it does today...unfortunatly theres no known 100% method of fixing the problem, First try uninstalling the sound device and rebooting to see if that fixes the sound or if its still not working usually the only other method is reinstalling vista. :(
alright, i'll try that.
i had this problem last time i was running vista, and this is a clean installation, so reinstalling vista isn't going to help me.
edit: reinstalled the driver, still pops.
    Asus P5GC-MX/1333
    2gb ddr2 ram
    nvidia 8500
Sound Blaster audio cards have many compatibility problems with vista.
Dead Navigation sound,eco sound in gaming etc
I hope the create better driver soon
    Custom Built by me.
    Intel Core 2 Quad Q6600
    Gigabyte GA-X38-DS4
    KINGSTON HYPERX DDR2 4GB (2X2GB) PC6400 800MHZ DUAL CHANNEL KIT
    SAPPHIRE RADEON HD4890 OC 1GB GDDR5
    2/4/5.1/7.1-channel Realtek High Definition
    Samsung LE40A656F1 1080p 100Hz LCD HD TV 50,000:1
    1366x768 in Desktop,1920x1080p in gaming and video
    C:\WD VelociRaptor 150 GB,10,000 RPM D:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 E:\WESTERN DIGITAL WD15EADS 1.5TB CAVIAR GREEN SATA2 No Raid.Copy Paste Is The Safest Way.
    Seasonic 700W 80plus
    A-Case Twin Engine BB
    3 thermaltake smart case fan II + 1 arctic cooling fan
    Wirelles Logitech Laser Mouse MX620
    Wireless Logitech LX710
    ADSL 4000plus
    F:\Sony high speed sata Dvd Rewriter KINGSTON HYPER X FAN +Cordless Rumblepad 2
... wow, it even does it with MICROSOFT drivers.
i'm using my lifechat lx-3000 headphones and the sound still pops. and their drivers are up to date.
this is pretty lame.
    Asus P5GC-MX/1333
    2gb ddr2 ram
    nvidia 8500
A reinstall was the only other way I have found to fix this problem if reinstalling the drivers had no effect, it only occurs on some installs and not others.
yeah, reinstalling my drivers doesn't seem to be working.
    Asus P5GC-MX/1333
    2gb ddr2 ram
    nvidia 8500
i have the same issue, some sounds have a staticness to them, for example if i go into sounds> and play the asstriks sound it will have a static-ness about it. i have swapped the speakers and its the same, also updated reltek drivers to latest ones and no change, i think i am going to buy a sound card and use that instead of the onbaord sound and see how i get on.
yeah, lame thing is, mine isn't onboard, and cost over 100 bucks.
    Asus P5GC-MX/1333
    2gb ddr2 ram
    nvidia 8500
I was about to try KXproject, but they are 32bit only.
    Asus P5GC-MX/1333
    2gb ddr2 ram
    nvidia 8500
Sorry, I realise this is an old thread, but I think this may help for people who come across this topic.
Basically, this is what I did to fix it (for my Microsoft LifeChat device):
>Control Panel
>Hardware and Sound
>Sound - Manage Audio Devices
>(Select your SPEAKERS)
>Properties
>Levels
>MUTE Microphone and turn it's volume down.
Hope that helps!
Again, sorry for the old topic post.
    Asus
    AMD Phenom(tm) 8650 Triple-Core Processor (3 CPUs), ~2.3GH
    ASUS M2N68-CM Motherboard
    4094MB RAM
    NVIDIA GeForce 9500 GT
    Speakers VideoLogic ZXR-550/Microsoft LifeChat LX-3000
    ViewSonic VE700
    1280 x 1024
    1TB Samsung
    ASUS TA-K5
    CPU Funnel
    Microsoft USB IntelliMouse Optical
    Microsoft Digital Media Pro Keyboard
    Dial Up
