Strange bootup
Angustevo
I've had this problem several times now on bootup.
It boots on the F2 setup screen does several seconds of the loading bar, then my screen says 'no signal' and it goes back to the F2 setup screen and freezes.
Then I have to turn of my computer by holding down the power button and start it again the second time where it boots fine.
Any ideas how to fix this?
i did had the no signal .all i did is turn my power supply off and on .
and about that booting problem the same thing happen to me .
i had to replace my hard drive .
so i did replace every thing in my pc .the only thing i did not change is the mobo .
    build by me last summer
    cpu.3.00.ghz
    asrock fm2 -75 pro
    g-skill 1333 7-7-7-21 4 gbs
    none
    none
    22 ecer x223w
    crusial m4 128 gbs
    apevia.atx-as500 blue led
    thermatake armor a 30
    5= 80 mm led fans
    logitech
    logitech mk 300
Hello Angustevo,
Before you replace anything try this.
Open a command prompt as administrator and type sfc/scannow press enter and let it scan, if it picks up any errors, scan again, until it is clear.
This will check your file system for errors.
Also, go to your HDD makers site and download their diagnostic software and test your HDD.
Give this a try and post your results, good luck.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
The command prompt scan says that it did not find any integrity violations, the HDD scan unfortunately won't work because Hitachi haven't updated it and it requires a floppy disk, I don't have a floppy disk drive...
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
