Strange BSOD
Hi guys, my first time posting searched on google and it seemed here was the only good place i can put my problem up to be solved :)
Ive had this computer for alittle good while now, and just recently ive been getting BSODs with i couldnt pinpoint what is causing it, i have attached two dumps thanks for and help :)
    Gigabyte
    i7 920 stock
    ex-58-extreme
    10gb ram
    gtx480
    22' benq
    3x1tb
    770w
0x0000000A: IRQL_NOT_LESS_OR_EQUAL
Typically due to a bad driver, or faulty or incompatible hardware or software. Technically, this error condition means that a kernel-mode process or driver tried to access a memory location to which it did not have permission, or at a kernel Interrupt ReQuest Level (IRQL) that was too high. (A kernel-mode process can access only other processes that have an IRQL lower than, or equal to, its own.)
Code:
icrosoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp1_Mini092410-01[1].zip\Mini092310-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (8 procs) Free x64
Built by: 6002.18267.amd64fre.vistasp2_gdr.100608-0458
Machine Name:
Kernel base = 0xfffff800`02448000 PsLoadedModuleList = 0xfffff800`0260cdd0
Debug session time: Thu Sep 23 01:31:35.330 2010 (GMT-4)
System Uptime: 0 days 3:06:35.652
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck A, {fffffa801d28dc9a, 2, 0, fffff80002497f76}
Probably caused by : memory_corruption ( nt!MiRestoreTransitionPte+ea )
Followup: MachineOwner
1: kd> !analyze -v
IRQL_NOT_LESS_OR_EQUAL (a)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is usually
caused by drivers using improper addresses.
If a kernel debugger is available get the stack backtrace.
Arguments:
Arg1: fffffa801d28dc9a, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, bitfield :
 bit 0 : value 0 = read operation, 1 = write operation
 bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status)
Arg4: fffff80002497f76, address which referenced memory
Debugging Details:
OVERLAPPED_MODULE: Address regions for 'IDSvia64' and 'IDSvia64.sys' overlap
READ_ADDRESS: GetPointerFromAddress: unable to read from fffff8000266f080
 fffffa801d28dc9a
CURRENT_IRQL:  2
FAULTING_IP:
fffff800`02497f76 8a411a          mov     al,byte ptr [rcx+1Ah]
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0xA
PROCESS_NAME:  System
TRAP_FRAME:  fffffa6001f93780 -- (.trap 0xfffffa6001f93780)
NOTE: The trap frame does not contain all registers.
Some register values may be zeroed or incorrect.
rax=00000000009b8498 rbx=0000000000000000 rcx=fffffa801d28dc80
rdx=0000000000000000 rsi=0000000000000000 rdi=0000000000000000
rip=fffff80002497f76 rsp=fffffa6001f93910 rbp=0000058000000000
 r8=0000000000000000  r9=0000000000000000 r10=0000000000000000
r11=fffffa8008d19f20 r12=0000000000000000 r13=0000000000000000
r14=0000000000000000 r15=0000000000000000
iopl=0         nv up ei ng nz na pe cy
nt!MiRestoreTransitionPte+0xea:
fffff800`02497f76 8a411a          mov     al,byte ptr [rcx+1Ah] ds:fffffa80`1d28dc9a=??
Resetting default scope
LAST_CONTROL_TRANSFER:  from fffff800024a226e to fffff800024a24d0
STACK_TEXT:
fffffa60`01f93638 fffff800`024a226e : 00000000`0000000a fffffa80`1d28dc9a 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx
fffffa60`01f93640 fffff800`024a114b : 00000000`00000000 fffffa80`08c43730 00000000`00000001 fffffa80`07b5ea40 : nt!KiBugCheckDispatch+0x6e
fffffa60`01f93780 fffff800`02497f76 : fffffa60`01f93908 00000000`00000000 00000000`00000000 fffffa60`01f93a01 : nt!KiPageFault+0x20b
fffffa60`01f93910 fffff800`0253ab75 : fffffa80`07b5ea40 fffff800`02448000 00000000`00291f8c fffffa80`1010a300 : nt!MiRestoreTransitionPte+0xea
fffffa60`01f93970 fffff800`0253b29c : fa8008d1`9f9004c0 ffffffff`ffffffff 00000000`00000011 fffff800`024956dd : nt!MiRemoveStandbyPage+0xe5
fffffa60`01f939b0 fffff800`024f7f95 : fffffa80`09060980 fffff800`0255cf59 fffff880`13e5cd02 fffff800`026a7e60 : nt!MiRemoveLowestPriorityStandbyPage+0x2c
fffffa60`01f939e0 fffff800`02464024 : fa8008d1`9f9004c0 fffffa80`0fd5a0b0 00000000`00000006 fffffa80`08d19f20 : nt! ?? ::FNODOBFM::`string'+0x10785
fffffa60`01f93a40 fffff800`026a7bd7 : fffffa80`1013f330 00000000`00000001 00000000`0b990000 fffffa60`0613007f : nt!MiPfPutPagesInTransition+0x348
fffffa60`01f93b40 fffff800`02468149 : fffffa80`1013f330 00000000`0b990000 fffff800`025d98a0 fffffa80`07f18388 : nt!MmPrefetchForCacheManager+0x6b
fffffa60`01f93b90 fffff800`0248cffa : fffffa80`0fda8e90 fffffa60`00000000 fffffa80`0d4cfd20 00020000`00000000 : nt!CcPerformReadAhead+0x2a5
fffffa60`01f93c70 fffff800`024a98c3 : fffffa80`07f202f0 fffff800`026458d0 fffffa80`0d610400 00000000`00000000 : nt!CcWorkerThread+0x236
fffffa60`01f93cf0 fffff800`026acf57 : fffffa80`07f202f0 00000000`00000000 fffffa80`07f18290 00000000`00000080 : nt!ExpWorkerThread+0xfb
fffffa60`01f93d50 fffff800`024df656 : fffffa60`005ec180 fffffa80`07f18290 fffffa60`005f5d40 fffffa60`005ec7f0 : nt!PspSystemThreadStartup+0x57
fffffa60`01f93d80 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiStartSystemThread+0x16
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  3
SYMBOL_NAME:  nt!MiRestoreTransitionPte+ea
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: nt
DEBUG_FLR_IMAGE_TIMESTAMP:  4c0e5ae3
IMAGE_NAME:  memory_corruption
FAILURE_BUCKET_ID:  X64_0xA_nt!MiRestoreTransitionPte+ea
1: kd> lmtsmn
start             end                 module name
fffffa60`029c1000 fffffa60`029d0f00   1394BUS  1394BUS.SYS  Sat Jan 19 01:34:04 2008 (479199DC)
fffffa60`008e9000 fffffa60`0093f000   acpi     acpi.sys     Sat Apr 11 01:03:26 2009 (49E0249E)
fffffa60`05c92000 fffffa60`05cfd000   afd      afd.sys      Sat Apr 11 01:44:21 2009 (49E02E35)
fffffa60`0b33c000 fffffa60`0b347000   asyncmac asyncmac.sys Sat Jan 19 01:37:27 2008 (47919AA7)
fffffa60`00be7000 fffffa60`00bef000   atapi    atapi.sys    Sat Apr 11 01:34:19 2009 (49E02BDB)
fffffa60`009d5000 fffffa60`009f9000   ataport  ataport.SYS  Sat Apr 11 01:34:25 2009 (49E02BE1)
fffffa60`0600d000 fffffa60`060fa000   BHDrvx64 BHDrvx64.sys Fri Aug 27 18:11:09 2010 (4C7837FD)
fffffa60`0adcc000 fffffa60`0adea000   bowser   bowser.sys   Sat Jan 19 00:54:51 2008 (479190AB)
fffffa60`05f3b000 fffffa60`05fd7000   ccHPx64  ccHPx64.sys  Fri Feb 05 16:05:45 2010 (4B6C8829)
fffff960`006a0000 fffff960`006b1000   cdd      cdd.dll      unavailable (00000000)
fffffa60`061d8000 fffffa60`061f4000   cdfs     cdfs.sys     Sat Jan 19 00:53:45 2008 (47919069)
fffffa60`029de000 fffffa60`029fa000   cdrom    cdrom.sys    Sat Apr 11 01:34:39 2009 (49E02BEF)
fffffa60`006bf000 fffffa60`00771000   CI       CI.dll       Sat Apr 11 03:08:09 2009 (49E041D9)
fffffa60`0140e000 fffffa60`0143a000   CLASSPNP CLASSPNP.SYS Sat Apr 11 01:34:15 2009 (49E02BD7)
fffffa60`00662000 fffffa60`006bf000   CLFS     CLFS.SYS     Sat Apr 11 00:54:21 2009 (49E0227D)
fffffa60`06148000 fffffa60`06156000   crashdmp crashdmp.sys Sat Apr 11 01:34:31 2009 (49E02BE7)
fffffa60`0143a000 fffffa60`01444000   crcdisk  crcdisk.sys  Sat Jan 19 01:30:12 2008 (479198F4)
fffffa60`05f1e000 fffffa60`05f3b000   dfsc     dfsc.sys     Sat Apr 11 00:54:44 2009 (49E02294)
fffffa60`013e3000 fffffa60`013f7000   disk     disk.sys     Sat Apr 11 01:34:38 2009 (49E02BEE)
fffffa60`03c46000 fffffa60`03c69000   drmk     drmk.sys     Sat Jan 19 02:20:04 2008 (4791A4A4)
fffffa60`01444000 fffffa60`0155e000   dump_iaStor dump_iaStor.sys Sun Jul 20 20:29:34 2008 (4883D86E)
fffffa60`06156000 fffffa60`06162000   Dxapi    Dxapi.sys    Sat Jan 19 01:08:00 2008 (479193C0)
fffffa60`03aa3000 fffffa60`03b84000   dxgkrnl  dxgkrnl.sys  Sat Apr 11 01:10:13 2009 (49E02635)
fffffa60`00fce000 fffffa60`00ffa000   ecache   ecache.sys   Sat Apr 11 01:36:18 2009 (49E02C52)
fffffa60`05e83000 fffffa60`05ef9000   eeCtrl64 eeCtrl64.sys Fri May 21 17:44:45 2010 (4BF6FECD)
fffffa60`05a41000 fffffa60`05a61000   ENG64    ENG64.SYS    Thu Jul 01 14:11:13 2010 (4C2CDA41)
fffffa60`05ef9000 fffffa60`05f1e000   EraserUtilRebootDrv EraserUtilRebootDrv.sys Fri May 21 17:44:45 2010 (4BF6FECD)
fffffa60`05840000 fffffa60`059fa000   EX64     EX64.SYS     Thu Jul 01 14:19:15 2010 (4C2CDC23)
fffffa60`029d1000 fffffa60`029de000   fdc      fdc.sys      Sat Jan 19 01:28:45 2008 (4791989D)
fffffa60`00cc4000 fffffa60`00cd8000   fileinfo fileinfo.sys Sat Jan 19 01:05:23 2008 (47919323)
fffffa60`03dce000 fffffa60`03dd9000   flpydisk flpydisk.sys Sat Jan 19 01:28:45 2008 (4791989D)
fffffa60`00c0f000 fffffa60`00c56000   fltmgr   fltmgr.sys   Sat Apr 11 00:54:38 2009 (49E0228E)
fffffa60`05b63000 fffffa60`05b6d000   Fs_Rec   Fs_Rec.SYS   Sat Jan 19 00:53:41 2008 (47919065)
fffffa60`011cf000 fffffa60`011fb000   fwpkclnt fwpkclnt.sys Sat Apr 11 01:42:44 2009 (49E02DD4)
fffffa60`02800000 fffffa60`0280d000   GEARAspiWDM GEARAspiWDM.sys Mon May 18 08:17:04 2009 (4A1151C0)
fffff800`02402000 fffff800`02448000   hal      hal.dll      Sat Apr 11 03:04:56 2009 (49E04118)
fffffa60`0280f000 fffffa60`028fc000   HDAudBus HDAudBus.sys Sat Apr 11 01:39:38 2009 (49E02D1A)
fffffa60`05b0a000 fffffa60`05b1c000   HIDCLASS HIDCLASS.SYS Sat Apr 11 01:39:32 2009 (49E02D14)
fffffa60`05b1c000 fffffa60`05b23b80   HIDPARSE HIDPARSE.SYS Sat Jan 19 01:33:51 2008 (479199CF)
fffffa60`05b01000 fffffa60`05b0a000   hidusb   hidusb.sys   Sat Apr 11 01:39:32 2009 (49E02D14)
fffffa60`0ad00000 fffffa60`0ada3000   HTTP     HTTP.sys     Sat Feb 20 16:30:05 2010 (4B80545D)
fffffa60`00acd000 fffffa60`00be7000   iaStor   iaStor.sys   Sun Jul 20 20:29:34 2008 (4883D86E)
fffffa60`00a06000 fffffa60`00acd000   iastorv  iastorv.sys  Fri Sep 28 14:32:10 2007 (46FD48AA)
fffffa60`05e00000 fffffa60`05e76000   IDSvia64 IDSvia64.sys Thu May 27 04:07:18 2010 (4BFE2836)
fffffa60`01581000 fffffa60`01594000   intelppm intelppm.sys Sat Jan 19 00:52:45 2008 (4791902D)
fffffa60`05805000 fffffa60`0582c000   Ironx64  Ironx64.SYS  Tue Apr 27 20:48:23 2010 (4BD785D7)
fffffa60`03d5c000 fffffa60`03d6a000   kbdclass kbdclass.sys Sat Jan 19 01:28:05 2008 (47919875)
fffffa60`05b58000 fffffa60`05b63000   kbdhid   kbdhid.sys   Sat Apr 11 01:33:40 2009 (49E02BB4)
fffffa60`00609000 fffffa60`00613000   kdcom    kdcom.dll    Sat Apr 11 03:07:57 2009 (49E041CD)
fffffa60`03c69000 fffffa60`03c9d000   ks       ks.sys       Sat Apr 11 01:33:51 2009 (49E02BBF)
fffffa60`00d13000 fffffa60`00d9a000   ksecdd   ksecdd.sys   Mon Jun 15 09:15:18 2009 (4A364966)
fffffa60`03c9d000 fffffa60`03ca2180   ksthunk  ksthunk.sys  Sat Jan 19 01:28:14 2008 (4791987E)
fffffa60`05a98000 fffffa60`05aa5c00   ladfDHP2amd64 ladfDHP2amd64.sys Fri May 15 16:24:42 2009 (4A0DCF8A)
fffffa60`05aa6000 fffffa60`05b00b00   ladfSBVMamd64 ladfSBVMamd64.sys Fri May 15 16:24:31 2009 (4A0DCF7F)
fffffa60`03de4000 fffffa60`03de7d80   LGBusEnum LGBusEnum.sys Mon Nov 23 20:36:48 2009 (4B0B38B0)
fffffa60`0b347000 fffffa60`0b349480   LGVirHid LGVirHid.sys Mon Nov 23 20:36:48 2009 (4B0B38B0)
fffffa60`05b24000 fffffa60`05b39000   LHidFilt LHidFilt.Sys Thu Mar 18 04:51:17 2010 (4BA1E985)
fffffa60`0ac9e000 fffffa60`0acb2000   lltdio   lltdio.sys   Sat Jan 19 01:35:48 2008 (47919A44)
fffffa60`05b44000 fffffa60`05b58000   LMouFilt LMouFilt.Sys Thu Mar 18 04:51:24 2010 (4BA1E98C)
fffffa60`06175000 fffffa60`06197000   luafv    luafv.sys    Sat Jan 19 00:59:06 2008 (479191AA)
fffffa60`00613000 fffffa60`0064e000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Apr 11 03:05:41 2009 (49E04145)
fffffa60`06162000 fffffa60`06175000   monitor  monitor.sys  Sat Jan 19 01:32:34 2008 (47919982)
fffffa60`03d6a000 fffffa60`03d76000   mouclass mouclass.sys Sat Jan 19 01:28:05 2008 (47919875)
fffffa60`05b39000 fffffa60`05b44000   mouhid   mouhid.sys   Sat Jan 19 01:28:10 2008 (4791987A)
fffffa60`009c2000 fffffa60`009d5000   mountmgr mountmgr.sys Sat Jan 19 01:28:01 2008 (47919871)
fffffa60`06197000 fffffa60`061b1000   mpsdrv   mpsdrv.sys   Sat Jan 19 01:35:28 2008 (47919A30)
fffffa60`061b1000 fffffa60`061d8000   mrxdav   mrxdav.sys   Sat Apr 11 00:55:42 2009 (49E022CE)
fffffa60`05fd7000 fffffa60`06000000   mrxsmb   mrxsmb.sys   Tue Feb 23 06:32:22 2010 (4B83BCC6)
fffffa60`0b20d000 fffffa60`0b256000   mrxsmb10 mrxsmb10.sys Tue Feb 23 06:32:21 2010 (4B83BCC5)
fffffa60`0b256000 fffffa60`0b275000   mrxsmb20 mrxsmb20.sys Tue Feb 23 06:32:20 2010 (4B83BCC4)
fffffa60`05bbb000 fffffa60`05bc6000   Msfs     Msfs.SYS     Sat Jan 19 00:53:55 2008 (47919073)
fffffa60`00948000 fffffa60`00952000   msisadrv msisadrv.sys Sat Jan 19 01:02:50 2008 (4791928A)
fffffa60`03b9d000 fffffa60`03bd6000   msiscsi  msiscsi.sys  Sat Apr 11 01:36:09 2009 (49E02C49)
fffffa60`00d9a000 fffffa60`00dea000   msrpc    msrpc.sys    Sat Apr 11 01:32:13 2009 (49E02B5D)
fffffa60`03de8000 fffffa60`03df3000   mssmbios mssmbios.sys Sat Jan 19 01:02:54 2008 (4791928E)
fffffa60`013d1000 fffffa60`013e3000   mup      mup.sys      Sat Apr 11 00:54:47 2009 (49E02297)
fffffa60`00e0b000 fffffa60`00fce000   ndis     ndis.sys     Sat Apr 11 01:43:15 2009 (49E02DF3)
fffffa60`03cc6000 fffffa60`03cd2000   ndistapi ndistapi.sys Sat Jan 19 01:37:22 2008 (47919AA2)
fffffa60`03cd2000 fffffa60`03d03000   ndiswan  ndiswan.sys  Sat Apr 11 01:43:39 2009 (49E02E0B)
fffffa60`00dea000 fffffa60`00dfe000   NDProxy  NDProxy.SYS  Sat Jan 19 01:37:26 2008 (47919AA6)
fffffa60`05d5f000 fffffa60`05d6e000   netbios  netbios.sys  Sat Jan 19 01:36:35 2008 (47919A73)
fffffa60`05cfd000 fffffa60`05d41000   netbt    netbt.sys    Sat Apr 11 01:42:31 2009 (49E02DC7)
fffffa60`01000000 fffffa60`01059000   NETIO    NETIO.SYS    Sat Apr 11 01:43:34 2009 (49E02E06)
fffffa60`05bc6000 fffffa60`05bd7000   Npfs     Npfs.SYS     Sat Apr 11 00:54:22 2009 (49E0227E)
fffffa60`05dd6000 fffffa60`05de2000   nsiproxy nsiproxy.sys Sat Jan 19 01:36:45 2008 (47919A7D)
fffff800`02448000 fffff800`0295f000   nt       ntkrnlmp.exe Tue Jun 08 10:59:47 2010 (4C0E5AE3)
fffffa60`01205000 fffffa60`01385000   Ntfs     Ntfs.sys     Sat Apr 11 00:55:38 2009 (49E022CA)
fffffa60`05b6d000 fffffa60`05b76000   Null     Null.SYS     Thu Nov 02 05:37:15 2006 (4549BC4B)
fffffa60`03aa1000 fffffa60`03aa2180   nvBridge nvBridge.kmd Fri Jul 09 17:07:54 2010 (4C378FAA)
fffffa60`007d7000 fffffa60`007fa000   nvhda64v nvhda64v.sys Mon Jun 21 18:07:25 2010 (4C1FE29D)
fffffa60`02e0f000 fffffa60`03aa0e00   nvlddmkm nvlddmkm.sys Fri Jul 09 17:15:58 2010 (4C37918E)
fffffa60`029af000 fffffa60`029c0b00   ohci1394 ohci1394.sys Sat Apr 11 01:39:49 2009 (49E02D25)
fffffa60`05d41000 fffffa60`05d5f000   pacer    pacer.sys    Sat Apr 11 01:42:56 2009 (49E02DE0)
fffffa60`00982000 fffffa60`00997000   partmgr  partmgr.sys  Sat Apr 11 01:34:51 2009 (49E02BFB)
fffffa60`00952000 fffffa60`00982000   pci      pci.sys      Sat Apr 11 01:03:33 2009 (49E024A5)
fffffa60`009ab000 fffffa60`009b2000   pciide   pciide.sys   Sat Apr 11 01:34:28 2009 (49E02BE4)
fffffa60`009b2000 fffffa60`009c2000   PCIIDEX  PCIIDEX.SYS  Sat Apr 11 01:34:22 2009 (49E02BDE)
fffffa60`0b34a000 fffffa60`0b400000   peauth   peauth.sys   Mon Oct 23 07:57:00 2006 (453CAE0C)
fffffa60`03c0b000 fffffa60`03c46000   portcls  portcls.sys  Sat Apr 11 01:39:36 2009 (49E02D18)
fffffa60`0064e000 fffffa60`00662000   PSHED    PSHED.dll    Sat Apr 11 03:08:17 2009 (49E041E1)
fffffa60`05bd7000 fffffa60`05be0000   rasacd   rasacd.sys   Sat Jan 19 01:37:30 2008 (47919AAA)
fffffa60`03ca3000 fffffa60`03cc6000   rasl2tp  rasl2tp.sys  Sat Apr 11 01:43:37 2009 (49E02E09)
fffffa60`03d03000 fffffa60`03d13000   raspppoe raspppoe.sys Sat Apr 11 01:43:33 2009 (49E02E05)
fffffa60`03d13000 fffffa60`03d31000   raspptp  raspptp.sys  Sat Apr 11 01:43:38 2009 (49E02E0A)
fffffa60`03d31000 fffffa60`03d49000   rassstp  rassstp.sys  Sat Apr 11 01:43:46 2009 (49E02E12)
fffffa60`05d89000 fffffa60`05dd6000   rdbss    rdbss.sys    Sat Apr 11 00:55:21 2009 (49E022B9)
fffffa60`05ba9000 fffffa60`05bb2000   RDPCDD   RDPCDD.sys   Sat Jan 19 01:42:04 2008 (47919BBC)
fffffa60`05bb2000 fffffa60`05bbb000   rdpencdd rdpencdd.sys Sat Jan 19 01:42:03 2008 (47919BBB)
fffffa60`0acb2000 fffffa60`0acca000   rspndr   rspndr.sys   Sat Jan 19 01:35:48 2008 (47919A44)
fffffa60`05609000 fffffa60`05772f80   RTKVHD64 RTKVHD64.sys Thu Jul 24 06:05:39 2008 (488853F3)
fffffa60`0295f000 fffffa60`029af000   Rtlh64   Rtlh64.sys   Wed Jun 23 05:21:24 2010 (4C21D214)
fffffa60`03be3000 fffffa60`03bf1000   ScreamingBAudio64 ScreamingBAudio64.sys Thu Nov 26 01:04:57 2009 (4B0E1A89)
fffffa60`0b200000 fffffa60`0b20b000   secdrv   secdrv.SYS   Wed Sep 13 09:18:38 2006 (4508052E)
fffffa60`05c77000 fffffa60`05c92000   smb      smb.sys      Sat Apr 11 01:42:19 2009 (49E02DBB)
fffffa60`013c9000 fffffa60`013d1000   spldr    spldr.sys    Mon Jan 12 16:51:29 2009 (496BBB61)
fffffa60`0ac04000 fffffa60`0ac9e000   spsys    spsys.sys    Tue Mar 10 13:16:43 2009 (49B6A07B)
fffffa60`05773000 fffffa60`057f9000   SRTSP64  SRTSP64.SYS  Wed Feb 24 18:59:29 2010 (4B85BD61)
fffffa60`0582c000 fffffa60`05840000   SRTSPX64 SRTSPX64.SYS Wed Feb 24 18:59:48 2010 (4B85BD74)
fffffa60`0b2a7000 fffffa60`0b33c000   srv      srv.sys      Fri Jun 18 11:26:47 2010 (4C1B9037)
fffffa60`0b275000 fffffa60`0b2a7000   srv2     srv2.sys     Fri Jun 18 11:26:21 2010 (4C1B901D)
fffffa60`0ada3000 fffffa60`0adcc000   srvnet   srvnet.sys   Sat Apr 11 00:57:28 2009 (49E02338)
fffffa60`01594000 fffffa60`015f1000   storport storport.sys Sat Apr 11 01:34:45 2009 (49E02BF5)
fffffa60`03de2000 fffffa60`03de3480   swenum   swenum.sys   Thu Nov 02 05:37:33 2006 (4549BC5D)
fffffa60`00c56000 fffffa60`00cc4000   SYMDS64  SYMDS64.SYS  Mon Aug 17 19:35:30 2009 (4A89E942)
fffffa60`00cd8000 fffffa60`00d13000   SYMEFA64 SYMEFA64.SYS Wed Apr 21 17:47:39 2010 (4BCF727B)
fffffa60`05a0b000 fffffa60`05a41000   SYMEVENT64x86 SYMEVENT64x86.SYS Thu Aug 13 18:28:21 2009 (4A849385)
fffffa60`05c01000 fffffa60`05c77000   SYMTDIV  SYMTDIV.SYS  Tue May 04 00:38:27 2010 (4BDFA4C3)
fffffa60`01059000 fffffa60`011cf000   tcpip    tcpip.sys    Wed Jun 16 10:51:56 2010 (4C18E50C)
fffffa60`0adea000 fffffa60`0adfa000   tcpipreg tcpipreg.sys Tue Dec 08 12:55:32 2009 (4B1E9314)
fffffa60`03bd6000 fffffa60`03be3000   TDI      TDI.SYS      Sat Apr 11 01:44:14 2009 (49E02E2E)
fffffa60`05be0000 fffffa60`05bfd000   tdx      tdx.sys      Sat Apr 11 01:43:00 2009 (49E02DE4)
fffffa60`03d49000 fffffa60`03d5c000   termdd   termdd.sys   Sat Apr 11 01:48:13 2009 (49E02F1D)
fffff960`00410000 fffff960`0041a000   TSDDD    TSDDD.dll    unavailable (00000000)
fffffa60`01578000 fffffa60`01581000   tunmp    tunmp.sys    Sat Jan 19 01:36:30 2008 (47919A6E)
fffffa60`0156c000 fffffa60`01578000   tunnel   tunnel.sys   Sat Jan 19 01:36:44 2008 (47919A7C)
fffffa60`060fa000 fffffa60`06148000   udfs     udfs.sys     Sat Apr 11 00:54:21 2009 (49E0227D)
fffffa60`03d76000 fffffa60`03d86000   umbus    umbus.sys    Sat Jan 19 01:34:16 2008 (479199E8)
fffffa60`05a7f000 fffffa60`05a97280   usbaudio usbaudio.sys Sat Apr 11 01:39:34 2009 (49E02D16)
fffffa60`05a61000 fffffa60`05a7d000   usbccgp  usbccgp.sys  Sat Jan 19 01:34:04 2008 (479199DC)
fffffa60`05a7d000 fffffa60`05a7ee00   USBD     USBD.SYS     Sat Jan 19 01:33:53 2008 (479199D1)
fffffa60`0294e000 fffffa60`0295f000   usbehci  usbehci.sys  Sat Apr 11 01:39:36 2009 (49E02D18)
fffffa60`03d86000 fffffa60`03dce000   usbhub   usbhub.sys   Sat Apr 11 01:39:52 2009 (49E02D28)
fffffa60`02908000 fffffa60`0294e000   USBPORT  USBPORT.SYS  Sat Apr 11 01:39:39 2009 (49E02D1B)
fffffa60`028fc000 fffffa60`02908000   usbuhci  usbuhci.sys  Sat Jan 19 01:33:56 2008 (479199D4)
fffffa60`05b76000 fffffa60`05b84000   vga      vga.sys      Sat Jan 19 01:32:21 2008 (47919975)
fffffa60`05b84000 fffffa60`05ba9000   VIDEOPRT VIDEOPRT.SYS Sat Jan 19 01:32:25 2008 (47919979)
fffffa60`00997000 fffffa60`009ab000   volmgr   volmgr.sys   Sat Apr 11 01:34:49 2009 (49E02BF9)
fffffa60`00771000 fffffa60`007d7000   volmgrx  volmgrx.sys  Sat Apr 11 01:35:14 2009 (49E02C12)
fffffa60`01385000 fffffa60`013c9000   volsnap  volsnap.sys  Sat Apr 11 01:35:33 2009 (49E02C25)
fffffa60`05d6e000 fffffa60`05d89000   wanarp   wanarp.sys   Sat Apr 11 01:43:38 2009 (49E02E0A)
fffffa60`03b84000 fffffa60`03b94000   watchdog watchdog.sys Sat Apr 11 01:09:16 2009 (49E025FC)
fffffa60`00801000 fffffa60`008db000   Wdf01000 Wdf01000.sys Sat Jan 19 01:33:27 2008 (479199B7)
fffffa60`008db000 fffffa60`008e9000   WDFLDR   WDFLDR.SYS   Sat Jan 19 01:32:33 2008 (47919981)
fffff960`00020000 fffff960`002d4000   win32k   win32k.sys   unavailable (00000000)
fffffa60`03b94000 fffffa60`03b9d000   wmiacpi  wmiacpi.sys  Sat Jan 19 01:02:42 2008 (47919282)
fffffa60`0093f000 fffffa60`00948000   WMILIB   WMILIB.SYS   Sat Jan 19 01:33:45 2008 (479199C9)
fffffa60`0acea000 fffffa60`0ad00000   WUDFPf   WUDFPf.sys   Sat Jan 19 01:33:22 2008 (479199B2)
fffffa60`0acca000 fffffa60`0acea000   WUDFRd   WUDFRd.sys   Sat Jan 19 01:33:43 2008 (479199C7)
Report indicates that the problem was caused by memory. Take this memory test. Run for at least 8 scans.
Download memtest86 and test RAM
www.sevenforums.com/tutorials/105647-ram-test-memtest86.html
If this turns out negative, my next hunch would be a driver problem, which we will discuss if you get another BSOD, after taking corrective action.
Thanks for that richc46 i let it do 7 passes, it came back with no errors, i also had a look in my event viewer, and the only thing that seems abnormal, aside from me causing some errors is this strange little fella, appears shortly before and after the two BSODs i had ,
"Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected."
Application
WMI
Event ID 10
to my little understanding, i would say that a 32bit application is trying to access system resources?
    Gigabyte
    i7 920 stock
    ex-58-extreme
    10gb ram
    gtx480
    22' benq
    3x1tb
    770w
Although the report indicated that it was a memory problem, as you can see from the BC number a driver problem must also be suspect.
Code:
The suggested action is to update the old and the very old drivers. Due to the quanity involved it may be easier to update those with a date prior to 1/1/08 and take the driver verifier test. The test will cause BSOD and requires that you back up your doucments, pics etc.
In Addition:
If overclocking restore normal settings
SFC /scannow
System Files - SFC Command
Update outdated listed drivers. If I have inadvertently listed any Microsoft Drivers, they can be ignored.
Enable the Driver Verifier
www.sevenforums.com/crash-lockup-debug-how/65331-using-driver-verifier-identify-issues-drivers.html
Uninstall your current Anti Virus and replace with Microsoft Security Essentials.
www.microsoft.com/Security_Essentials/
Scan with your Anti Virus
How to Find Drivers
search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone - will help you search Google for the name of the driver
- - if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
- The most common drivers are listed on this page: http://www.carrona.org/dvrref.html
- - Driver manufacturer links are on this page: http://www.carrona.org/drvrdown.html
To remove any left over driver remnants, especially from graphics cards, use driver sweeper
www.guru3d.com/category/driversweeper/
After performing all of the above, post back with any new BSOD reports, or indicate that the attempted repairs were successful.
If any links do not work, if clicked, please copy and paste to browser address bar.
Remember that several attempts may be required before we can solve your BSOD problem. These reports are not definitive but merely point the way to a solution.
Thanks for all the useful information rich6!
iastorv.sys is for my RAID configuration, i believe its up-to-date
as for peauth.sys, it is a Microsoft service "This is the Protected Environment Authorization (PEAUTH) driver." - i believe windows update would update it if need be as i cant find any updated downloads from a quick search on google
similarly Null.sys is by microsoft, and i couldnt find any reliable place to download it - wouldnt Windows updater update it?
Also swenum.sys is by microsoft for PnP devices (also for DX .... come to think of it, i havnt installed DX11 will do so now)
secdrv.sys cant be updated as it runs off my DVDs programs / etc
i highly suspect that this indeed is the cause, the two BSODs happened while accessing the DVD / secure disk confirmation - free DVD application that it opens the program that i use sometimes overflows and leaks memory due to some WMI interference , ive read that disabling UAC will help prevent the problem by allowing 32 bit application use the WMI interface with elevated privileges, i have done so, and no BSODs as of yet (been 1 day since last)
however if i do get a BSOD i will be sure to post here :)
Thanks
(P.S which programs are needed to read .dumps / how to read them)
    Gigabyte
    i7 920 stock
    ex-58-extreme
    10gb ram
    gtx480
    22' benq
    3x1tb
    770w
Ignore any Microsoft Drivers, I should have deleted them.
For widows 7 64 bit Debugger for dump reading. YOu will have to search for Vista.
If you return with BSOD, I will give you the driver verifier, since you have so many old drivers. You will have to back up your stuff.
http://msdl.microsoft.com/download/symbols/debuggers/dbg_amd64_6.11.1.404.msi
Install that, and then download and extract both of these links to C:\Symbols:
http://download.microsoft.com/download/7/F/B/7FBF7E6A-D0DE-442A-A683-4F9885A96FC9/Windows_Win7.7600.16385.090713-1255.X86FRE.Symbols.msi
http://download.microsoft.com/download/F/1/1/F11206A1-C532-4C9E-86FF-1261A693AA53/Windows_Win7.7600.16385.090713-1255.X64CHK.Symbols.msi
thanks Richc46
    Gigabyte
    i7 920 stock
    ex-58-extreme
    10gb ram
    gtx480
    22' benq
    3x1tb
    770w
Ok just to report back...i got another BSOD its attached, i believe it should reveal the culprit as i had alot less running (i believe) in the background at the time...
its starting to get annoying and im considering reinstalling without my raid configuration.
    Gigabyte
    i7 920 stock
    ex-58-extreme
    10gb ram
    gtx480
    22' benq
    3x1tb
    770w
These reports do not give answers, they give clues. The more we have to more clues. We checked drivers already, this one indicates memory. I used my best guess and went with drivers the last time around.
Take the memory test for 8 passes. It will be over night
STOP 0x0000000A: IRQL_NOT_LESS_OR_EQUAL Usual causes: Kernel mode driver, System Service, BIOS, Windows, Virus scanner, Backup tool, compatibility
Uninstall your virus scanner and use Microsoft Security Essentials, at least for test purposes.
Ok richc46 .... might also like to add that my 1TB of external HDD full of my files, programs, personal stuff over 800gb of it .... all gone, disk management says its "unallocated"
    Gigabyte
    i7 920 stock
    ex-58-extreme
    10gb ram
    gtx480
    22' benq
    3x1tb
    770w
Remove the externel Hard Drive. We will use it as little as possible, so that after the problem is resolved we can get your documents.
Again, Memtest returned no errors...
    Gigabyte
    i7 920 stock
    ex-58-extreme
    10gb ram
    gtx480
    22' benq
    3x1tb
    770w
BC A, which is what you have is normally very easy to diaganose. Its either driver or hardware. In some situations it is the Anti Virus. As directed in my earlier post, uninstall your anti virus and use Microsoft Security Essentials, at least for testing purposes. Then come back if you have additional BSODs
Intall any new hardware recently
Make any changes?
The only changes i have recently made are adding an extra 4 GB of ram into my system, and setting up two HDDs in Raid 0
i am fairly sure that my raid 0 config controller by intel matrix is causing the problem, only because i had just realised the BSOD happened when indexing / using heavily my external HD which is connected to the intel controller, it either must be my Raid controller or 4GB of RAM failing, i might also add i have 6Gb in triple channel and 4Gb in dual - i usually clock them to the same freq / timings (6gb matching the 4gb) - but if the RAM was the cause, wouldnt it return errors on the memtest?
Also, is it possible to recover all my files lost in my external HD? windows says its "RAW" with 0 bytes of free and used space, and i pretty much cant do anything on my system if i dont have access to those files :(
Thanks
    Gigabyte
    i7 920 stock
    ex-58-extreme
    10gb ram
    gtx480
    22' benq
    3x1tb
    770w
thanks tichc46 i will do, thanks for all your support, much appreciated :)
    Gigabyte
    i7 920 stock
    ex-58-extreme
    10gb ram
    gtx480
    22' benq
    3x1tb
    770w
Hi richc i reinstalled my OS / formatted my ext HDD
i got a BSOD once OS finished installing...
dump attached
Thanks
    Gigabyte
    i7 920 stock
    ex-58-extreme
    10gb ram
    gtx480
    22' benq
    3x1tb
    770w
First do not install any programs until we get this sorted.
This error code was
STOP 0x0000001A: MEMORY_MANAGEMENT Usual causes: Device driver, memory, kernel
You said that you did the memory test the way I had asked, about 8 passes.
The driver in question this time is
rdyboost.sys, which is a Micorosoft Driver and most likely not the cause. I think we have to do the driver verifier test.
Run for 36 hours even if you get BSODs. As you get BSODs post them
Thanks richc will do
might also like to note, it happened as soon as i logged in, my event viewer says that SVCHOST.exe -k has a possible memory leak
    Gigabyte
    i7 920 stock
    ex-58-extreme
    10gb ram
    gtx480
    22' benq
    3x1tb
    770w
Ok i got a BSOD...but its not in my dumps???? its really fast too
Ok i think it may be my DVD / Drive causing the BSOD because it only happens when i try to load something off it,
heres the drivers i selected in driver verifier
amdxata.sys
dump_dumpfve.sys
dump_iastor.sys
gdrv.sys
iastor.sys
rdyboost.sys ( i understand its by windows, but you mention it earlier so i thought id give it a shot)
and last secdrv.sys
    Gigabyte
    i7 920 stock
    ex-58-extreme
    10gb ram
    gtx480
    22' benq
    3x1tb
    770w
