IvanI
Hello!
I recently installed Vista x64 Business on my macine (specs are below).
I downloaded the newest drivers directly from NVIDIA:
GeForce Release 178
I started the installation ,everything worked fine, BUT...at the end of the "green install bar" it stopped for a few minutes and then finished saying "The software didn't not make any device changes" or something like that. I was puzzled since those are WHQL drivers.
When I closed the install program, Vista came up with the standard:"This program might have not installed correctly." Then I was really worried.
I reinstalled Windows again just be sure but I got the same thing.
Well, after that second take, I restarted the computer, and everything worked fine (!!!)
Drivers were up, properly displayed in device manager ,everything working. Since then I'm running Aero, playing games, 3dmark vantage went well...
I shared this with you just to see if anyone had any similar experience?
GeForce Release 178
- Custom build
- Intel Core 2 Duo E6600 @ default 2.4GHz
- ASUS P5B Deluxe
- 4x2GB Kingmax DDR2@800MHz
- Point of View GeForce 8800GTS (G92), 512MB GDDR3
- ADI SoundMax 5.1 (onboard)
- Samsung SM 2232BW, 22" LCD
- 1680x1050@60Hz
- Seagate Baracuda 7200.10 (ST3160815AS), 160GB @ SATA-II Seagate Baracuda 7200.10 (ST3320620AS), 320GB @ SATA-II
- PSU
- Corsair HX520, 520W modular
- Case
- Antec P183
- Cooling
- Scythe SCNJ-1000 ("big Ninja") + Scythe 120mm
- Logitech MX Revolution
- Microsoft Ergo 4000
- ADSL2+ @ 3Mbit/384kbit
- Other Info
- 3Dmark Vantage: P7134 | H4262
