svchost.exe SYSTEM using 50% process time
VosperD
HP laptop with Vista 32 bit..
svchost.exe is using 50% of the cpu. When checking which services it is running it highlights 16 items all in the group netsvcs. Only one or two of these I can locate in the services panels. Is there any way I can isolate the cause of the problem?
Regards
Don
    Homebuilt
    AMD Phenom 8650 2300mHz
    Gigabyte M720-US3
    4 gb
    Creative audigy 2 zs
    LG19"
This is likely due to your updates as you determined in your other thread. This thread isn't needed. Please work on this in your other thread.
    Windows 7 Pro & 10 Pro
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB & 500 GB
OK. Will do.
At the time of posting I thought this was a a separate issue.
Cheers
    Homebuilt
    Gigabyte M720-US3
    4 gb
    LG19"
I have a similar issue except that it's using more than 50%. Could I be pointed in the direction of this "other thread"? Also I assume when you say "Process time" are you referring to the CPU usage?
