System is 1 month old.
Gateway FX6800 6Gb Ram, i7 CPU
System locks up every 3 days +/- or so.
System is now approx. 2 hours since reboot. TM reports.
Physical: 6134
Cached: 4299
Free: 34
Physical Memory Usage show 2.1Gb/35%
Over the course of the 3 days the amount of Physical Memory Used will grow to 5.5Gb+ at which time the system slows down to a crawl and the system needs to be rebooted.
There are 3 users with accounts on the system and all stay logged in 100% of the time. Switching between users as necessary. Early warning of the system needing to be rebooted is the system taking 10+ minutes to switch between users.
If I add up the reported (in TM) Working Set of RAM for all of the running applications it adds up to only a fraction of the amount of physical memory reported as being used.
I at first thought the problem was related to Norton 360. But after uninstalling/reinstalling it several times and eventually leaving it uninstalled the problem is still there.
Any thoughts or steps I should take to help diagnose?
Thanks
Physical: 6134
Cached: 4299
Free: 34
Thanks
- Gateway FX6800-09
- Intel i7
- 6Gb
- Nvidia GTX 280
- ST31000340AS - 1Tb
Ted
Ted
