System Recovery Fails
c4kays
HP Pavilion a6400f
Windows Vista SP1
"Windows Setup could not configure Windows to run on this computers hardware".
PC had Windows Update problems and was never upgraded to SP2.
Windows Updates didn't work and the Stand-alone SP1 also didn't work.
Told the owner I'd have to do a complete System Recovery, Install/Repair wouldn't work.
Recovery discs were made but lost.
Recovery Partition still good.
Was able to backup all the data using Safe Mode.
The recovery completes and then the above message appears.
I can move it forward a little by doing the following:
At the first error hit SHIFT F10
Type -
Cd..
Cd..
Cd c:\windows\system32\oobe
Msoobe
After the first time, it moved me to the User Name Logon before it happened again.
Now I can get to the "Thank you"
"Start"
When I click "Start", there's a long, like loading, delay, "....checking your computer's performance"
Then the same message appears "Windows Setup.......Hardware"
in a "Install Windows" message box.
I have a full Vista Ultimate DVD if I could use that.
BTW, owner's one of my kid's teachers so this is like a favor.
    HP Pavilion a6400f
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz, 3401 Mhz, 4 Core(s)
    16GB
    NVIDIA GeForce GTX 750, Intel(R) HD Graphics 4600
    Samsung 27" C27F398 Curved Monitor
    1920 x 1080 (HDMI)
    Samsung SSD 840 EVO 250GB Seagate ST2000NM001 2TB Seagate ST31500341AS 1.5TB
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP xw4400 Workstation
    Intel Pentium D Dual 3.4Ghz
    HP 0A68h
    5GB
    Realtek HD Audio
    Acer KN242HYL 24" (KVMS)
    1920X1080
    Seagate ST3120026As 120GB SATA (boot) Toshiba DT01ACA200 2TB SATA
    Logitech via KVMS switch
    Dell USB via KVMS switch
    50 Down, 10 Up
    Apache Web Server since 2001
Thanks, neighbor. (I'm down US1 on the Treasure Coast)(Hutchinson Island)
Had everything OK as far as your excellent tutorial went until the final setting up when the same screen appeared.
Used a Vista Ultimate OEM I had and managed to get it installed.
Now fighting the SP1 install battle but I'll get it.
Glad someone is still around when we get a Vista problem.
Thanks again.
Pete
    HP Pavilion a6400f
That download includes SP1, you need SP2 then all the updates.
    Windows 10 Pro X64
    16GB
    1920 x 1080 (HDMI)
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP 0A68h
    5GB
    Realtek HD Audio
    1920X1080
    50 Down, 10 Up
OK, square 1. The OEM that I had didn't work. Remind me why I didn't like working on Vista.
I've created the iso but it won't boot.
Is there something that needs to be done with the
install.wim 3.3GB
boot.wim
I've got them downloaded
The only file I put into the iso creator was the X14-63452.exe
    HP Pavilion a6400f
Did you follow the directions in the tutorial I gave you the link to? It has all the steps needed in there.
Download files
Run wbicreatore to gen the iso
Run imgburn to create a DVD ot Universal USB Installer to create a install flash drive.
    Windows 10 Pro X64
    16GB
    1920 x 1080 (HDMI)
    500W
    Lenovo USB
    50MB Down, 10MB Up
    Windows 7 Pro X64
    HP 0A68h
    5GB
    Realtek HD Audio
    1920X1080
    50 Down, 10 Up
