System Restore fails
Stevex
Used SR in the past no problem, but have just tried to restore to a previous point and at the very end of the process (after auto re boot) I get a window telling me it failed and asks me if I want to try a different restore point. I tried a second one with the same result. Anyone got any advice please?
How much space is left in the restore partition?
Hello Stevex,
There are a couple of things you can try.
Try the SR in safe mode.
Also, you can try turning off your AV, see if that helps. (has been known to interfere with SR in the past).
Hope this helps, good luck and post your results.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
How do I check this, and how will space left alter the points already there?
I have actually reduced the space available for Restore points so it only ever stores 3 of them, but didn't have a problem before.
Click on computer icon on destop, . It should show partion and space used.
Is there anything in your logs that tell you why the restore has failed.
Click on the start menu, then right click on my computer and choose manage.
This will bring up different options one being the event viewer.
This may shed some light.
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
Error 8209, it may work in safe mode as Stoney suggested.
Warning, if you do it in safe mode, you cannot undo, via SR.
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
I tried it and it does indeed work, Stu.
