Solved System Restore Not Working
David4321
Hello
My system restore fails every time I attempt it. This has happened the last 3 times I had a need to attempt restore. (Three attempts separated by months in time, about different issues.) This time, I am thinking something may be wrong with my system restore function.
In this case, it is simply a matter of trying to roll back a browser update.
I saw a whole list of available restore points, and I went to the second one back - from only a few days ago. The restore failed.
I am using Windows Vista Home Premium, OEM from Gateway Laptop about 1.5 yrs old. I allow most updates.
Any Suggestions? Thanks.
Solution
Solution:
The problem was caused by Norton NIS 2009.
The problem was resolved by the following steps:
Go into Settings - Miscellaneous Settings - Product
Security and turn off 'Norton Product Tamper Protection'.
Then System Restore worked.
David4321
Well done for solving your own problem & for suppling others with a helpful suggestion.;)
    1440 x 900
    Laptop / notebook.
    Stock.
    IBM enhanced
    ADSL [ Too slow.]
    Webcam.
