How to Enable or Disable Create Vista System Restore Point when New Device Driver is Installed
This will show you how to enable or disable System Restore from creating a restore point automatically when you install or update a new device driver on your computer.
This is enabled by default in Vista
System Restore will need to be turned on for Vista to be able to create a restore point.
NOTE: This method is only available for the Vista Business, Ultimate, and Enterprise editions. See OPTION TWO or OPTION THREE below for the Vista Basic and Home Premium editions.
1. Open the Local Group Policy Editor.
2. In the left pane, click on Computer Configuration, Administrative Templates, System, and Device Installation. (See screenshot below)
3. In the right pane, right click on Do not create system restore point when new device driver installed and click on Properties. (See screenshot above)
4. To Enable Create System Restore Point for Device Driver Install
A) Select (dot) Disabled or Not Configured and click on OK. (See screenshot below step 5A)
B) Go to step 6.
5. To Disable Create System Restore Point for Device Driver Install
A) Select (dot) Enabled and click on OK.
6. Close the Local Group Policy Editor window. Your done.
NOTE: This method will work for all Vista versions.
1. To Enable Create System Restore Point for Device Driver Install
A) Click on the Download button below to download the file below.
Enable_SR_Device_Install.reg
B) Go to step 3.
2. To Disable Create System Restore Point for Device Driver Install
Disable_SR_Device_Install.reg
5. Click on Run, Continue (UAC), Yes, and then OK when prompted.
6. When done, you can delete the downloaded .reg file if you like.
7. Log off and log on, or restart the computer to apply.
1. Open the Start Menu.
3. Click on the Continue button in the UAC prompt.
4. In regedit, go to: (See screenshot below)
NOTE: If you do not have DeviceInstall, then right click on Windows and click on New and Key. Type DeviceInstall and press Enter.
HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\DeviceInstall
A) In the left pane, right click on DeviceInstall and click on New and Key. (See screenshot above)
B) Type Settings and press Enter. (See screenshot below)
C) In the right pane, right click on a empty area and click on New and DWORD (32-bit) Value. Type DisableSystemRestore and press Enter. (See screenshot below)
D) Right click on DisableSystemRestore and click on Modify.
E) Type 1 and click on OK. (See screenshot below)
F) The registry will now look like this. (See screenshot below)
G) Go to step 7.
6. To Enable Create System Restore Point for Device Driver Install
A) In the right pane, right click on DisableSystemRestore and click on Delete. (See screenshot above)
B) Click on Yes to confirm the deletion.
That's it,Shawn
Related Tutorials
- How to Create a System Restore Shortcut in Vista
- How to Create a Create System Restore Point Shortcut in Vista
- How to Create a System Restore Point in Vista
- How to Undo the Last System Restore in Vista
- How to Do a System Restore in Vista
- How to Turn System Restore On or Off in Vista
- How to Use Disk Cleanup in Vista
- How to Stop System Restore Points from being Deleted in Vista when Dual Booting with XP
- How to Change the Automatic System Restore Point Settings in Vista Task Scheduler
- How to Change the System Restore Disk Space Usage in Vista
- How to Enable or Disable Create Vista System Restore Point when a Application is Installed
