System restore without monitoring?
Hairy Scot
I apologise if this has been covered before, but after searching for quite some time I have found nothing, so here goes:-
What I am looking for is the ability to create system restore points manually without the overhead of the monitoring function which is required by the automatic process.
Hey there Hairy Scot,
I am not quite sure what you are asking. Do you want to create a system restore point then disable it so it wont automatically make them?
Let us know and sorry for the confusion,
Ben
    Dell
    Intel(R) Celeron(R) CPU 420 @1.60 GHz
    Dell Inspion 530 Default
    PNY 4GB 240-Pin SDRAM DDR2 800 (PC2 6400) Dual Channel
    ATI Radeon HD 2400 PRO
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Seagate 250G ATA SATA-II
    Dell Inspiron 530
    None
    Logitech EX100 Combo
    100 MB/s
Hello Harry,
I'm not sure if this is what you wanted, but you can disable the System Restore tasks in Task Schedular to disable the automatic creation of restore points. The tutorial below can help show you how to.
http://www.vistax64.com/tutorials/1...-change-automatic-restore-point-schedule.html
You might also find using the shortcut in the tutorial below will make it even easier to manually create restore points when you like.
http://www.vistax64.com/tutorials/72805-system-restore-point-shortcut.html
    Dell
    Q6600
    HP w2207h
Sorry if my question was not clear.
I want full manual, not automatic, control of System Restore.
Automatic control involves the monitoring function which results in significant disc activity.
Turning off System Restore causes deletion of the previously created recovery points, so that is not a viable option.
I appreciate that there are numerous products I could use to achieve my aims, but it seems a pity that a facility like System Restore has to be so restricted.
Hello Harry,
Thanks for that Shawn, I will read the articles and try out the solutions.
Hello Harry,
Hi Shawn,
That certainly covers most of the problem, and I found an interesting item on shadow copies (Controlling Shadow Copies in Vista (and Windows 7!) - Solutions by PC Magazine).
Now for the next step :geek:
When creating the restore point manually: if there are multiple discs or volumes is it possible to select a specific disc or volume?
Yes, you select your disk/volume here:
    Dell
    Q6600
    HP w2207h
That screen differs from the one I see on my system, and as I mentioned earlier, turning system restore off deletes the previously created restore points.
My system restore screen looks like this :-
Glad to here everything is all set hairy. Ênjoy şir
Have a good one,
Ben
    Dell
    Realtek HD Audio
    Gateway PnP Monitor
    1024x768 @ 75 Hz
    Dell Inspiron 530
    None
    100 MB/s
Yeah, that is a problem indeed. You will always end up with that one only. Imaging would be so much easier.
Your screen is a little different because mine is Win7 - but basically the same thing.
    Dell
    Q6600
    HP w2207h
Hello Harry,
Hi Shawn,
You're welcome Hairy.
Yes, that will allow you to change the maximum amount of disk space to be used for storing restore points.
http://www.vistax64.com/tutorials/76227-system-restore-disk-space.html
Did you get everything the way you wanted it?
