System Restore Won't Work
Tx Dad
First, I have Vista Ultimate 32 bit.
My problem is I can't get the "System Restore" to work. Every time I set it to do a system restore, it appears to go through all the right motions. Then after it shuts down and restarts itself, I get an error message:
"System restore did not complete successfully."
"An unspecified error occurred during system restore."
It goes on to say that the computers settings have not changed.
What's going on? I've tried several different checkpoints including one that I had manually set myself. None of them work, I always get the same error message.
Anybody else ever run into this problem?
yes I have but I have noticed that System Restore in Vista is not worth much. It's not like xp where you can go back several days or even a week or two. From what I've seen you can only go back about 24 hrs. ... just my 2cents...
FATBOY
    RJ's Toyz/HOTROD
    DFI LanParty UT P45-T2RS
    G.SKILL 8GB (4 x 2GB)
    24" and 22" Acer LCDs
    1920 x 1200 / 1680 x 1050
    PC Power & Cooling 1200W
    Cooler Master HAF932
    Logitech G9 @28grams
    Logitech G15 Gamer
    very very very slow
    3DMARK06 = 23114
This is not true, because I once picked out a restore point way back a month or so ago.
    E6850
    EVGA 122-CK-NF67-A1 680i
    4 x OCZ Platinum 1GB
    ATI Radeon HD 5850 1GB
    SB X-Fi X Audio
    Samsung 23" 5MS
    2048 x 1152
    Seasonic 600W M12
    CM Centurion 5
    air
    100Mbps
Mine won't do it...never has :(
    RJ's Toyz/HOTROD
    Logitech G15 Gamer
    very very very slow
    3DMARK06 = 23114
Somehow a duplicate message got saved. Mods, please delete.
    Intel Q6600 Quad Core 2.4 Ghz
    Dell 0TP406
    Nvidia 8800 GT 512 MB
    Dual Dell 22" Widescreen
    3360x1050
    320 GB Internal Main 500 GB USB External 160 GB USB External 2TB USB External
    DSL 3MB
One option would be to do a system repair using the Vista DVD, depending on whats wrong. This may help your situation if restore is not available to you.
    Dell 0TP406
    3360x1050
    DSL 3MB
I seem to recall that if you are running Norton Anti-virus and the Norton Files under Norton Options are protected the system restore will return that message. I remember having that problem with Windows XP, I don't know if it applies to Vista 32 bit. It does not apply to Vista 64bit which I am running.
    AMD 945
    Asus M5A99X EVO
    ATI 6770
thank you for that info....my computer is only a month old and it won't do a system restore...it has a free 60 day trial of Nortons on it.....
I will delete that...put on a new AV and see what happens...hopefully I can do a system restore
I wonder if this has been resolved, I have this same problem?
    Gateway Mod: GM5407E Ser: 1009401706
    Intel(R) Pentium(R) D CPU 3.00GHz, 3000MHz 2core)s), 2 Logis
    Gigabyte: GA-E7AUM-DS2H
    6MB
    NVADA Geoforce 9400
    Built-in
    ACER X193w
    1440X900
    Brand unkown, size 283.5GB NTFS
    Tower
    CPU & 2 Case Fans
    USB Human Inerface (Logitech)
    Standed PS2
    DSL
    This Machine has a problem 'It will NOT log onto my banks sites or anything to do with bank it refuses
If you have Norton or similar anti virus program, In Norton, go into settings, and untick Norton tamper proof box, then try again good luck.
Thanks Patch, Someone, (from these forums) advised me to try system restore in the Safe Mode! I did and it worked.
    6MB
    NVADA Geoforce 9400
    Built-in
    ACER X193w
    1440X900
    Tower
    CPU & 2 Case Fans
    Standed PS2
    DSL
