Solved system restore
vicf1
how do you set system restore on a dual boot windows vista and win 10
thank you
    toshiba
    2 core
    4 gb
    intel
    1200x800
Hello vicf1, and welcome to Vista Forums. :)
You can turn on system protection for each OS, but be sure to not have it turned on for the W10 drive in Vista, and not for the Vista drive in W10.
If you do, you may have your restore points deleted each time you start into the other OS.
thank you. I will do that and where can set the amount of disk space in windows vista for restore points? I can't find it
    toshiba
    2 core
    4 gb
    intel
    1200x800
I'm afraid it's something that has to be set manually in Vista, but the tutorial below can help show you how to.
System Restore - disk space
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
Glad we could help. :)
yes thanks
And I'm trying to learn by reading posts here
    toshiba
    2 core
    4 gb
    intel
    1200x800
