I am having a problem with Smart Defrag?
I have checked the box which says - load with windows at start up
Well, everytime I start windows, it does not put the icon in the system tray, like it should?
But if I uncheck the box, then check the box again, restart windows it shows in the system tray?
I have uninstalled it, but still the problem exists?
I even made a short cut to the startup folder, but it still will not add the icon to the system tray?
Is there a registry hack, that I can do, to make it show in the tray?, all the time?
Hmmm... Because I am tired of unchecking/checking the load up box...
Can anyone please help me with this?
Thanks
Riptorn
Thanks
Riptorn
- Dell Inspiron 1525
- CELERON DUO
- 4GB
- 360GB
